Results 1 to 10 of 24
Thread: Max Tracks or Ricks Tracks?
Threaded View
  1. #23
    Advanced Rick111's Avatar
    Ipswich QLD
    Quote Originally Posted by happygu View Post
    I have never used my Maxtrax for myself, and they have already lost a heap of lugs from someone else spinning their tyres all over them .......
    Just be careful, apply power gently, and you will be ok ....
    Your original method was better in most cases as wheel spin cant destroy the plastic grates
    Thanks guys for your replies. The thing that really killed them was the wheel spin, which TREDS & MAX tracks advise to keep to a minimum. As I said i am now purchasing the TREDS as they give a LIFETIME warranty compared to MAX Traks 2 year warranty. I really think after my experience that even the MAX Tracks will fail after a few years, which is why I think they only give a 2 year warranty.
    After handing over my hard earned money, I would much rather have the security of knowing mine are covered for a LIFETIME. Of course the other problem is usually things under a specific warranty will fail after the 2 year period, even if they have never been used.
    Thats just my 2 cents worth, but you make up your own minds.
    Note: RVTEK have a special on at the moment $199 including Freight: Tred Total Recovery Extraction Device Pair 1100mm RED 4x4 4WD MUD Trax Gear | eBay http://api.viglink.com/api/click?for...r%20%7C%20eBay
    $179 + postage, cheaper if you live in SE QLD: TRED - TOTAL RECOVERY & EXTRACTION DEVICE PAIR 1100MM GUNMETAL GREY 4X4 4WD GEAR - Tred http://store.rvtek.com.au/tred-total...air-1100mm~527
    "If you want it done right, you had better do it yourself"
  2. The Following 2 Users Say Thank You to Rick111 For This Useful Post:
    Clunk (10th September 2014), Sherro (10th September 2014)
