Results 1 to 10 of 11
Thread: Donaldson Filter
    Advanced Snow Patrol's Avatar
    Jul 2014
    Snowy Mountains NSW
    Donaldson Filter
    I am just about to fit a Donaldson P902976 filter kit to my GU6. Just wondering if anyone has fitted one and where they located it. I know keeping fuel cool is a good idea for the common rail but under the bonnet seems to be the only logical place.
    2008 Patrol 3.0L 2" Raw Nitro Lift, Polyair airbags, Airflow snorkel, Drawers, UHF, Dual battery system and cage scavenged from my Prado Alloy roof basket from the chookyard. Boost and EGT gauges and NADS
    1980 MQ Ute (nearly forgot the indestructible farm Ute)
    Under the bonnet is the only place. Are you getting rid of the OEM fuel filter? If not I would put if before the OEM filter maybe as those filters are cheaper to replace than the OEM ones. Exactly where? Where there is room I suppose. I am assuming you will need to make up a bracket of some sort...
    Snow Patrol (6th September 2014)
    Jul 2014
    Snowy Mountains NSW
    I'm goining to keep the OEM filter. Had a good look yesterday and looks like the easiest spot is over near the ABS unit. Also probably the hottest near the exhaust/turbo. Just thought I may have been overlooking the obvious...........still might be.....
    Wrong side of the motor isn't it? Fuel filter is on the right side on your car isn't it. Maybe need to move the OEM filter and pre fab a bracket to fit the two together.
    Jul 2014
    Snowy Mountains NSW
    Yeah I am going to have to do something along those lines. No room at all on the drivers side. I cant even get to the water drain on the stock filter.
    Aug 2014
    Armadale, Perth
    The GQ TD42 had the fuel filter in the left had corner adjacent to the bonnet hinge basically. I have retro fitted a high mount turbo and the fuel filter is still there.
    Haven't had any issues with fuel in mine and to my knowledge it has had no effect on performance in the last 13years the turbo has been there. No additional maintenance and I think from memory I only replaced the rubber fuel line about 12 months ago and that was more due to the body lift making the line taught.
    Not sure how close you would be to the exhaust in your setup but I doubt it would be too much of a problem
  8. The Following User Says Thank You to Patrolling Paddy For This Useful Post:
    Oct 2010
    Old Bar, NSW
    Fitted a cav filter here, not sure if you can but it gives you an idea.
    Macca
  10. The Following User Says Thank You to macca For This Useful Post:
  11. #8
    Advanced batesy's Avatar
    cranbourne vic
    I dont think your supposed too fit a second filter to a crd to hard for the pump to suck fuel through, better off just with a water watch they reckon, just what i have heard.
  12. #9
    Patrol Freak kevin07's Avatar
    georges hall
    Quote Originally Posted by batesy View Post
    yep been told the same thing to much pressure for the pump
    13 y62 the beast that burbles
  13. #10
    Expert NewDan's Avatar
    Oct 2011
    Didn't know you couldn't fit a second filter to a crd. I bought one with it already fitted. have had it for a year now.
    Dan
    #1. 2007 Walkabout, Auto, 2" EFS lift, DP chip, 3" Exhaust, cross country intercooler, front and rear diff locks, manual torque convertor lockup, bulbar, IPF driving light, Dawes valve, Boost, EGT and transmission temp gauge, 80 Channel UHF, Black widow storage system, ARB duel wheel carrier. 215 Litre fuel. #2 GQ 95Ti TB42e.
