Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Max Tracks or Ricks Tracks?
    Advanced Rick111's Avatar
    Ipswich QLD
    Hi fellas, I'm heading down to the Victorian High Country in December & I wanted to make sure I have the ability to recover myself from any predicamant that I may get myself into. A set of Max Tracks or TREDS was high on my wish list but the price they were asking for them I just couldn't justify, so I came up with these, I call them "Ricks Tracks", total cost $70 (8 water drain covers from 'Masters', and some zip ties.
    I tied 2 together side by side as I couldn't get them any wider than 100mm, to give a total width of 200mm X 1100mm long, much the same as the Max Tracks & TREDS, but for less than 1/4 of the cost for 4 treads! The more zip ties you put on the better grip you will get, make sure they are good quality zip ties.
    I have tried them in sand and they work a treat, I'm pritty sure they will work well in the mud too.
    Have a great day guys
    ATTACH=CONFIG]48887[/ATTACH]2014-09-03 13.45.33.jpg2014-09-03 13.45.42.jpg2014-09-03 13.45.57.jpg2014-09-03 13.46.40.jpg
    "If you want it done right, you had better do it yourself"
  2. The Following 6 Users Say Thank You to Rick111 For This Useful Post:
    gaddy (3rd September 2014), lucus30 (3rd September 2014), MudRunnerTD (3rd September 2014), my third 256 (4th September 2014), oncedisturbed (3rd September 2014), threedogs (4th September 2014)
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Never thought about using them. How do they hold up with the weight of the troll on top?
    www.swat4x4.com
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Good idea. I Guess they would be strong enough as I gather they would be designed for cars to travel over
    Lucus30's 1999 GU ST TB45E
    Expert Hardyards's Avatar
    Townsville
    Hey Rick,
    I like your idea to have a load spreading device without the price tag, will be interested to see if they work in mud. The slots may let through too much liquid, limiting the traction ability, and not sure how much distortion your tracks can handle running over them while not having a solid base underneath ie placed over a hole?
    Better than nothing if you cannot afford the tested, proven devices I reckon. Let us know how they perform
    Go the pig, I miss the D&B
    2006 GUIV DX 4.2 TDI Ute, Bullbar with Warn winch, Narva round spotties, scrub bars and side steps, Snorkel, Dual Battery system, Waeco fridge, 2 x Narva spotties an 80W solor panel on roof, Custom tray, 3" Redback exhaust, Bluemax 2 - EGT/Boost Oil press/Temp and dual volt gauges, Lifted, front locked and fully loaded......
    If you can't stand behind our troops, feel free to stand in front of them!
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Be interesting how they go in mud, they are pretty slippery compared to Maxtrax. Wonder if they would give better traction if turned upside down, I think the ridges underneath would give more bite.
    Jack
    2024 Isuzu MUX
    Patrol God Stropp's Avatar
    38 Post(s)
    good idea, i would use them upside down to give the tyres some grip
    brisbane
    I've seen the bases of bread trays used and they worked well so can't see why they wouldn't
    Legendary happygu's Avatar
    Rick,
    For the High Country, in December, you are very unlikely to have to use them anyway, but good thinking.
    The highest use you would have at that time is a bridge over ruts or washaways in the tracks, so make sure that they hold the vehicle weight ( having said that, I have never used any recovery aids in Summer in the High Country ever )
    Mic
  10. #9
    Ipswich QLD
    Thanks for all your responses guys, I'll take all comments good or bad. This weekend I'm going out to try and find some mud, I'll try to get it on video and see how they go. As I said I have tried them in sand and they work a treat.
  11. #10
    178 Post(s)
    Quote Originally Posted by happygu View Post
    Are MaxTrax to Treds strong enough to be used in that way?
