Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: 4.2 motor failure
  1. #31
    83 Post(s)
    Could it be that the engine is very tight and needs a head lubricant in the fuel, or does that only work with petrol engines?
  2. #32
    Wongan Hills
    Everything checked out on motor , has been over United Fuel Injection Dyno , and retuned - power increased to normal , but still runs hot , waiting for warmer weather to test more
  3. #33
    Jan 2013
    What temp does it run at? Good to hear the power is back.
  4. #34
    Wongan Hills
    Quote Originally Posted by Dales300exc View Post
    Runs just under half , at idle and normal driving .... I think this is about 84'c , am thinking of getting a digital temp gauge for more accuracy
  5. #35
    Jan 2013
    Ill be happy if mine runs at 84. Need something more than the factiry gauge for any accuracy.
  6. #36
    Thats about where my gu sits and never really moves from there. I have had aftermarket gauges on them and half can be between 70-80 which is pretty much where you want it. 84 degrees is pretty good.
  7. #37
    Wongan Hills
    Trouble is , when I put caravan on & climb a long hill (not steep) , temperature keeps rising - goes to 3/4 on a cool day with no aircond ... when its at 84'c and idling the thermostat is fully open - have checked stroke on thermostat - it opens to 41mm above 84'c - hence it closes off the bypass under the thermostat - just too much heat coming from engine ??
  8. #38
    What radiator was installed? Are you running coolant or just water?
  9. #39
    Wongan Hills
    running factory coolant
    Radiator is copper/brass twin core , original was aluminium/plastic
    Have been following this site as well http://www.patrol4x4.com/forum/engin...ot-td42-62472/
  10. #40
    Quote Originally Posted by boke View Post
    Do you still have the original?
