Results 11 to 20 of 23
Thread: Tyre size on 17 alloys
    brisbane
    He's not westys accessories any more but worth a shot still here is a quote from him .. Not sure if the link will work though
    Thanks Guys for the Recommendation.
    Hi pjbim10, i make a few different styles of light mount. 100% bolt on and now in 316 stainless steel.
    Check out my Threads HERE (<<link) an you can see them in the different threads.
    I have only just started the stainless ones, so yet to have any installed pics. But i can do telescopic or fixed for both the square galv and the stainless round, to suit GQ and GU.
    I also do many options which are listed in each thread, like color matching, custom heights to suit your needs, and even a heavier wire to handle a bigger light if you see fit.
    Anyway, jump over and have a look and if you have any questions feel free to throw us a pm.
    brisbane
    Ok link won't work but drop him a pm
  3. #13
    Advanced Gavshe's Avatar
    Jul 2014
    Boyne Island Qld
    I have a Y61 2013, just curious if the 285/70R17's have clearance issues on standard suspension setup, is a suspension mod needed
  4. #14
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Quote Originally Posted by old steve View Post
    Does anyone know if 285/70R17 will fit the rear wheel carrier ? i remember looking at the dealer ( haven't picked it up yet ) that there was almost zero clearance with the std spare , and the std tire od is 785 mm
    Hi mate,
    I needed to add a spacer to fit 285/70R17 KM2 to the rear door.
    Jack
    2024 Isuzu MUX
  5. #15
    Quote Originally Posted by Gavshe View Post
    You will almost certainly have to remove your front mud flaps if you don't have a lift but that's all.
    As stated you will need a spacer for your back door. ARB sell a spacer for $89 from memory. Easy bolt on and allow for a larger wider tyre to be bolted to the door.
    Gavshe (20th July 2014)
  7. #16
    The door spacers are readily available on eBay too. Here are a few pics off google.
    ImageUploadedByMotorculture1405823217.304545.jpgImageUploadedByMotorculture1405823228.933675.jpgImageUploadedByMotorculture1405823244.394772.jpgImageUploadedByMotorculture1405823255.152150.jpgImageUploadedByMotorculture1405823266.485032.jpg
    Here is some pics of the rear door cracking that is too common when fitting larger tyres (even standard size can cause this! Go the rear bar for the win!!)
    ImageUploadedByMotorculture1405823342.335236.jpgImageUploadedByMotorculture1405823358.317052.jpg
  8. #17
    Search "GU spare wheel spacer" on eBay for a good selection including light mounts.
  9. #18
    SUCH IS LIFE Maxhead's Avatar
    ACT
    That's strange, I never needed a spacer. I wonder if the rim offset might have something to do with it?
    ________________________
    ______ 2017 D-Max _______
  10. The Following User Says Thank You to Maxhead For This Useful Post:
    MudRunnerTD (20th July 2014)
  11. #19
    Western suburbs of Melbourne
    11 Post(s)
    I have -13 offset with 305's on the rear door and no spacer.
  12. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
  13. #20
    I think I had to fit the spacer to allow the rear light bracket to clear. A 285 on the standard Nissan rim should be fine, not sure about the 305 being a little wider?
    The 305 on a -13 rim has been adjusted 23mm further out already from the Nissan offset of +10
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Maxhead (20th July 2014)
