Page 2 of 19 FirstFirst 1234 ... LastLast
Results 11 to 20 of 187
Thread: DIY CV and Swivel Hub Rebuild Thread
    Getting excited now folks!!! its all going back together.
    Disk On
    install the washer
    First nut
    then tension the Hub Nut up to 145ft/lb and turn the disk both ways to work the grease and take up the slack.
    Then undo the nut to zero tension, respin the disk and retighten to factory spec 3.6ft/lb (near hand tight).
  2. The Following 8 Users Say Thank You to MudRunnerTD For This Useful Post:
    10G (25th March 2024), Conradk (31st October 2014), graeme1969 (20th July 2014), NissanGQ4.2 (20th July 2014), Parksy (20th July 2014), Tanker (4th May 2015), Warwick89 (13th October 2014), Wine_maker (4th February 2018)
  3. #12
    Once you have tensioned your wheel bearings to the correct spec insert the new Brass locking tab.
    Install the locking nut and tighten
    Bend the tabs of the brass tab over the inner and outer nuts to lock them both in.
    Install the Hub Spacer
    Grease up the "Egg Ring" Bush
    Install.
    Install the Drive Clutch again.
    Using your multi grips grab the end of the axle and pull it out as far as you can!. You should expose the groove for the Cir-Clip. If you cant get it then something is not seated properly and you will likely have to strip back to the CV and go again! Very Very Frustrating at this time! Make sure you seat Everything well and correctly! 2mm at this time will break your heart! I Promise!.
    Install the Cir-Clip. then time for the Locking Hub. Take the opportunity to clean it out and regrease it ready for the next 100,000kms.
    Use the gasket Goo around the joint again. Keep that water out!
    Anti Seize the bolts and Bolt her up!
    Brake Calliper back on and bolt her up. Take the opportunity to check the brake pads.
    Refit your wheels and tighten your wheel nuts. Tension your wheel nuts to factory spec (147Nm or 108ft/lb) I make a point of greasing my wheel studs to allow the nuts to tension to spec. I have not had a wheel come off and always hold correct tension after tightening properly.
    DONT FORGET! FILL YOUR DIFF WITH OIL! Tip* heat the bottle of Oil in a Pot of hot water the heat up the oil as its thick stuff, it will make it heaps easier to pump in.
    Hope this has been of some help to you guys. Dont be shy if you get stuck. post a question and plenty here will be able to help.
    Cheers MudRunnerTD.
  4. The Following 12 Users Say Thank You to MudRunnerTD For This Useful Post:
    89GQ (9th November 2014), Conradk (31st October 2014), Family4x4 (17th February 2016), graeme1969 (20th July 2014), LandRoverGhost (19th July 2016), Miscy (19th April 2020), mojo53 (19th December 2015), my third 256 (14th July 2015), NissanGQ4.2 (20th July 2014), Parksy (20th July 2014), Robo (18th March 2016), Warwick89 (13th October 2014)
  5. #13
    Doing the above job is the bush can be tough. If you smash a CV in the bush then you will not be installing a full kit through the front end as above to get you back on the road but it is recommended when you get home. Look at that drain plug! the metal goes everywhere!
    A Smashed CV in the bush!!
    Danny was on hand for this one too.
    Yep think she's Knackered for sure!
    he's not a bad Navi! no hesitation! he was straight into it!
  6. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    graeme1969 (20th July 2014), Parksy (20th July 2014), scubasteve (20th July 2014), Warwick89 (13th October 2014)
  7. #14
    Expert graeme1969's Avatar
    Jun 2013
    Wesley Vale, Tas
    Thanks for the effort of putting this thread together. Much appreciated. Got me keen to give that a crack now.
  8. The Following User Says Thank You to graeme1969 For This Useful Post:
    MudRunnerTD (20th July 2014)
  9. #15
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Now disappointingly!! I did not get any pics of removing teh king pin bearings from the caps. They are a bit of a bugger to do but there is a trick to it!. Next time i do a set i will grab some pics and add them to this thread.
    I think you really need 2 add these missing pics and I just happen 2 know where where there is a swivel hub that need redoing.
    I've done it once when I broke my CV never again!!!!!!!!!!!!!!!!!!
    Great thread Daz
  10. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  11. #16
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Great write up. Certainly wish I had the skills to do this
    Lucus30's 1999 GU ST TB45E
  12. The Following User Says Thank You to lucus30 For This Useful Post:
  13. #17
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    This is awesome. Thanks for the write up.
    IMO and should be taken with a grain of salt.
  14. The Following User Says Thank You to Parksy For This Useful Post:
  15. #18
    Advanced scubasteve's Avatar
    Redland Bay, QLD, AUS
    Awesome write up mate I'm about to purchase a kit and get mine done and this is exactly what i was looking for. Much Appreciated
    1989 Ford Maverick: TB42s Carby, Snorkel, 3" king spring suspension lift, 2" body lift, aftermarket extractors, 33x12.5 mickey t MTZ's, 2.5: Sports Exhaust
  16. The Following User Says Thank You to scubasteve For This Useful Post:
  17. #19
    Great write up Dazz and will help many of members mate, well done!!!
  18. The Following User Says Thank You to AB For This Useful Post:
  19. #20
    Im trying to keep costs down a bit so looking at a kit on ebay. Im wondering if it looks like it will include everything thats needed.
    This is the one im looking at mainly because it includes the 54mm socket for the hub nuts.
    http://r.ebay.com/trN1oF
    cheers
