Results 1 to 10 of 16
Thread: Spare wheel carrier
    Jan 2013
    Adelaide
    Spare wheel carrier
    Hi guys,
    Need some advise on a spare wheel carrier vs barn door wheel carrier. I'm doing a trip up to the Kimberly next year traveling through the middle. Is the barn door wheel carrier up to the task on corrigatoins era, I have 33in wheels, or do you think I need to go with the new bumper and wheel carrier?
    Brad
    2005 GU IV 3L ST-S Mods: 3in Zorst, chipped, Autron egt, boost and dual voltage gauges, pillar pod, dual battery, IPF round spoties, Nissan alloy Bullbar.
    The GUIV have history for splitting the barn door at the base of the window due to the wheel weight hanging off it. Mine has not done this but plenty have. I have now fitted a rear bar and am very happy to have the weight off the door. Plenty of guys still travel with the wheel mounted there though.
    If you travel North with the wheel on the door just make sure you air down to 22psi to 25psi when you hit the dirt, it will help ALLOT!
    There are a few options for rear wheel carriers though and if you buy a rear bar then make sure it has a swing away mount of both sides regardless if you only fit 1 side at a time. having the option to buy a left side swing away with 3 jerrys or another spare wheel just for touring is a winner.
    Have a look at RASLAR Engineering in Victoria for a great bar at a good price.
  3. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    04OFF (16th July 2014), Badball (18th July 2014), Gavshe (20th July 2014), jay see (16th July 2014)
    Patrol God Stropp's Avatar
    38 Post(s)
    also if you are after a cheapy look at mcc, i have their bar with twin wheel carrier and haven't had problems although i did add a peice of angle from the mounting points forward so the angle stops it from sagging as a precautionary measure and i just got back from the meetup in the middle and did 8500 k all up and most of that was dirt road.
  5. The Following User Says Thank You to Stropp For This Useful Post:
    33" tyre is a lot of weight to carry on a door, I mounted mine internally but that suits my set up.
    Out of all the ones out there I think the Raslar is the winner as it has an option where you open the door the tyre swings with it.
    Now that's thinking and well priced as well, with great reverse lights as STD
  7. The Following 3 Users Say Thank You to threedogs For This Useful Post:
  8. #5
    Advanced Gavshe's Avatar
    Jul 2014
    Boyne Island Qld
    Thanks Threedogs and MudRunnerTD, sound advice
  9. #6
    Legendary happygu's Avatar
    Badball,
    Mine is still on the rear door as it suited me better in my sales roles for work - opening and closing the back door all day long, and has been for the last four Patrols - and I have travelled extensively all over, and had no issues.
    Having said that, my role has changed, and I would like to have a rear bar now, to get rid of the extra weight off the door....just think it is a good idea....
    One of the things that annoy me the most with the spare wheel directly on the rear door, is the amount of dust build-up that you can only really dislodge by opening and closing the door, and every time you open and shut the door, the dust just flies straight into the cab. Having the spare wheel separate will alleviate the dust issue, as you only need to open it once - and you can shut it with all the doors closed so any dust just flies away....
    Mic
  10. #7
    Advanced Davo65's Avatar
    Jul 2014
    Middle Swan,WA
    Who's mcc...???
  11. #8
    brisbane
    http://www.mcc4x4.com
    They are similar powerfull 4x4 rear bar
  12. The Following User Says Thank You to megatexture For This Useful Post:
    Stropp (24th July 2014)
  13. #9
    Patrol Guru
    NT
    Can anyone put a figure on the extra weight of a 33 over a 31" tyre? I realise it will change per tyre brand/style.
  14. #10
    A tyre rim combo could weigh as much as 45KG depending on what rim you use
    that would be Maximum IMO in a 305 x 16" combo.
