Results 1 to 6 of 6
Thread: GQ SWB - Bad vibration at 10 - 15kph
    Jun 2014
    Hi guys
    Just got myself a SWB Maverick Diesel, it is standard except a 2" lift and 33" Mud Terrains.
    When taking off at slow speed or driving at slow speed at around 10 - 15kph there is a bad vibration come through the vehicle and quite noisy. It goes away above that speed and can't be felt/heard any other time. As I'm new to these cars just wondering if anyone might have an idea what it could be?
    Usually caused due to the high angle in your tailshaft (common on lifted shortys) you will probably need to purchase gear box spacers that go between the cross member and where it bolts to your chassis rail on each side.
  3. The Following User Says Thank You to timmay556 For This Useful Post:
    rockpool (11th July 2014)
    have you broken an engine mount, stick it in neutral and give it a decent rev . Does the gear stick move heaps
    check with the bonnet up and see if engine wants to climb out of the engine bay
    rockpool (12th July 2014)
    Jun 2014
    Doesn't appear to be engine mount as there wasn't any movement when I revved it, it does seem to be the lift height as suggested by Timmay, so I'm looking at replacing the lift kit in it anyway as it looks more like a 3/4" lift and rides like crap, so I'll take it back down to the normal 2" lift and see if it goes away.
    Thanks for all your help guys.
    Expert 90mav's Avatar
    Dec 2012
    Gold Coast
    Gearbox spacers are an easy thing and cheap to make yourself. Just loosen the crossmember bolts and lower the box and put spacer in between to see how much you need. You may need to get longer boltsx8 and buy a heap of big flat washers to pack it down. Lots cheaper than a set of spring and a half hour job at best, esp if you have a rattle gun!
    GQ Wagon 4.2 carb 4inch lift of the road resting
    GU Rd28 Wagon 2 inch lift on the road now daily driver
    D22 Navara ZD30- in rehab pending being moved on.
    See this thread for some info that will be of use to you.
    Why-does-your-car-vibrate-after-giving-it-a-lift
