Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 62
Thread: For the brake genius out there.
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by 93patrol View Post
    Adjust your rear drums up until there is constant scraping of the shoes on the drum or I was told adjust until it locks the wheel and then back it off until the wheel moves with moderate pressure but can hear the brake shoes on the drum
    93 I have gone as far as I dare, I think its far enough the hub couldn't be turned but with the rim back on it turned with the motor and no excessive dragging noises.
    The drums were a PITA to get off and trying to turn the drum is near impossible with the slippry diff. Will have another go in the morning when my work mate gets here. Backing the adjuster off concerns me, its a shizzen to get to.
    Are you blocking it before or after the LSV? I believe the LSV returns to the master so you could have a dodgy LSV (proportional valve)
    Yep NN the rubber hose to the diff all the rest are pipes.
    Macca
  2. #22
    Sep 2011
    adelaide
    18 Post(s)
    G`day macca.
    I`m Not sure if the brakes can be adjusted with the drum on as it`s a long time since I`ve done a drum brake Patrol.
    If not then you have to make sure that there is not a lip on the drum as this will cause all sorts of grief.
    What I would do is drill a hole through the drum or the back plate to line up with the adjuster and put a rubber plug in it after the job is done.
    Going by what you have said the adjustment would seem to be your problem.
    To adjust it you should adjust the brakes up until they are looked solid then back them off until the wheel turns freely, but as said the LSD will give you some grief
    To turn the drum use a long bar across the wheel studs and also you can do one with the opposite drum off the car, this will at least make one side easier.
    Pity I`m in SA otherwise I`d help you out.
    best of luck mate
  3. #23
    Try putting the LSV to maximum and see what happens.
  4. #24
    Oct 2010
    Old Bar, NSW
    The pedal is firm when crimping the brake line after the LPV I assume that the valve is not the problem. This is a pain in the faarking ass.
    Macca
  5. #25
    Sorry mate I misread your post getting a little tired.
  6. #26
    Jul 2012
    North East Victoria
    4 Post(s)
    Quote Originally Posted by NP99 View Post
    Are they the mob near the railway line up the Bandiana end? The stuffed my tray back up years ago
    Yes, that's them!
    Remember that a high IQ doesn't make up for a lack of common sense.
    Learn from the mistakes of others - you won't live long enough to make them all yourself !
  7. #27
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Quote Originally Posted by Old Wal View Post
    Yes, that's them!
    Yep, stay clear of them. They wrecked my front end on my tray back, years ago!
    1999 GU 4500 dual fuel
    Il dado è tratto
  8. #28
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    You might need to get your drums skimmed to take the lip off. If you haven't had this done before this would be your problem. To make it easier to remove the drum back your adjuster way off. Don't worry it's a pain in the arse but you won't break it.
  9. #29
    Oct 2010
    Old Bar, NSW
    OK patrollers we have a solution to the problem.
    Went to brake place this morning, the problem is a Nissan design fault.
    As soon as I described what you had recommend I do he said is it a Patrol? Then showed me the problem and the fix.
    The bleed port in the cylinder is not at the top so air can not get out when bleeding.
    Either bend cylinder tubing to put it higher, a PITA. Or fill the top with rubber grease, the method I am going to try.
    This may help others with an annoying spongy pedal.
    Will try to get it done today and report back!
    Macca
  10. The Following 4 Users Say Thank You to macca For This Useful Post:
    93patrol (7th July 2014), Cuppa (7th July 2014), jack (7th July 2014), Old Wal (8th July 2014)
  11. #30
    Oct 2010
    Old Bar, NSW
    Sorry, Pearcey there is a access to the adjustment it's a pain but I'm getting better at using it.
    And 93 there is no lip fortunately, at least that's 1 less issue.
    Macca
  12. The Following User Says Thank You to macca For This Useful Post:
