Results 1 to 10 of 10
Thread: Aux Battery distribution re-wire
    Aug 2011
    Oakland OREGON, but in Aus on holiday
    I'm the second owner of this Patrol and bought a Waeco 80L dual zone refrigerator that was put in the back to run off a ?Navara 12vdc plug. The plug was fine what I found was very small wire, 12-14ga AWG (sorry haven't converted that measurement yet) duplex wire was run from the second battery to the left rear panel where there was the plug non-cigarette type. So the vdc loop was long for such a small wire and the amps the Waeco took at startup and was blowing fuses.
    I've done a lot of rewiring of boats and so I had a bunch of wire spools of various sizes with all the fittings. Even some stainless steel armor shielding picked up at the Boeing surplus store, say in '88-'89. Really used for RFI shielding in planes but also protects the wire from chaff, etc.
    So the first picture is of the existing feed wire (small) and the feed cable from the Piranha isolator.
    So, I would run a larger 6ga AWG ANCOR to a split bus at the back door and then disassemble reassemble the small existing pair into one combined feed pair appropriately labeled since black and red would be joined.
    I also pulled out of the marine bucket some battery terminal covers which I installed after soldering/crimping the lugs on the ends of the two feed wires.
    Each circuit would be fused, 20a for the now duplex 12ga and 50a for the 6ga, a terminal hood would go over the positive to prevent shorts.
    And so this is what the rear AUX panel/wiring looked like before (I have split off the neg before taking the picture from the old neg loop)
    To this ... (used the frame as a ground at the left rear post)
    More to follow in DIY storage as my drawers finally were folded ..
    2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
  2. The Following 7 Users Say Thank You to HuskyInAuz For This Useful Post:
    FNQGU (6th July 2014), Hodge (5th July 2014), lucus30 (5th July 2014), mudnut (4th July 2014), MudRunnerTD (4th July 2014), my third 256 (5th July 2014), Old Wal (5th July 2014)
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Sweet I plan to do similar. How hard is it to pull that rear quarter plastic off?
    Lucus30's 1999 GU ST TB45E
    176 Post(s)
    I'm pretty sure it just peels off slowly, it has those tabs at the back.
    Nice write up Husky .As I'm about to run wires to the back my self, some very good points there.
  5. The Following User Says Thank You to Hodge For This Useful Post:
    HuskyInAuz (6th July 2014)
    Sep 2013
    16 Post(s)
    Cool thanks. I'm planing to do a negative and positive bus with a compressor mounted in there
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Good idea for use of that space mate. Which compressor are you going to mount in there?
    I need to sort out a few more ideas in the cargo bay too, and you are giving me some motivation. Just got to pull the damn drawers out first...
    brisbane
    Check out Steve's setup, I like what he's done.
    This is towards the end post so you can see it just go back a few to the start http://www.nissanpatrol.com.au/forum...p-video/page30
    Aug 2011
    I was thinking about a slim third battery (50ah+/-) but since my purchase yesterday a compressor sounds good. Mounting... ah more garage engineering.
  10. #8
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    I'm still considering a water bladder for at least one side. The compressor could well be the option for the other side. Got to work out just how big a bladder can fit. Am thinking 30 litre-ish, maybe a 40 litre and fill it till it can't take any more.
  11. #9
    brisbane
    Quote Originally Posted by HuskyInAuz View Post
    Might be able to get a series of 6x 2volt ones to fit easier?
  12. #10
    Sep 2013
    16 Post(s)
    Quote Originally Posted by megatexture View Post
    I thought about it but could never find any batteries slim enough
