Results 1 to 10 of 12
Thread: *urgent* No low beam
    Beginner skits's Avatar
    Kalgoorlie
    Exclamation *urgent* No low beam
    I urgently need some help. I have no low beam on my GU Patrol. High beam works fine. All fuses are fine.
    I should listen to my wife
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Does the high beam light show on the dash when on low beam? Shake and wiggle the connectors behind the lights. This fixed my problem.
    1999 GU 4500 dual fuel
    Il dado è tratto
    Kalgoorlie
    na no high beam light only if high beam is on. Pulled globes out and they are both fine. they worked fine on the way home from work this morning.
    Advanced thebrod's Avatar
    Sep 2013
    hmmm could be a relay issue......
  5. #5
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Possibly an issue in the switch itself. I had a similar issue in mine, and a mate had the same in his. Pull the switch off, check the contacts for any blackness, and clean dirty contacts with a bit of fine sandpaper and some contact cleaner. Reassemble and see what happens.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  6. #6
    Expert clubbyr8's Avatar
    Penrith, NSW
    Quote Originally Posted by thebrod View Post
    There's no headlight relay in a GU patrol unless you have xenon lights, at least not in my 2010 GU VII.
    GROOVY GUVII
  7. #7
    Legendary happygu's Avatar
    Most likely culprit will be the switch, as it gets turned on and off a lot over a lifetime.
    Check for 12V at the globes when you turn on the low beams, and if no voltage, then check the wiring out of the switch
  8. #8
    Kalgoorlie
    we checked the relay box but there isnt any relays for the headlights, might have to check the switch out tomorrow, thanks guys.
  9. #9
    Oct 2013
    Port Hedland
    Sounds like a loose wire if its not the switch. Have you been working under the hood?
  10. #10
    Kalgoorlie
    no i havnt been working under the hood for a couple weeks. ill check the switch out and check voltage at the globes next,
