Results 1 to 10 of 13
Thread: How to keep engine oil clean
    Mar 2013
    G'day all. I drive a GUIV ZD30. I change the oil regularly and use an engine oil flush aswell. However within 500-800 km it's black as again.
    Do I have a dirty engine and if so how do I clean it up.
    Others are claiming their oil is only slightly burnt at oil change. Buggered if I'm anywhere near that. Any help greatly appreciated.
    Oct 2010
    Old Bar, NSW
    Our son-in-law is a diesel mechanic he said if the oil is clean you are using the wrong oil as it doesn't have cleaners in it. Even some known brands are not cleaning engines enough. They had 2 trucks using different oil, same engines. Removed rocker cover one was spotless the other had sludge around the low flow areas.
    Like you I know people that have clean oil at change time and was concerned. That was when we had a brand new Ute , it was filthy from the 1st change.
    Macca
    Aug 2010
    adelaide
    its the soot in the oil from the combustion of the fuel
    OH LEATHER IS NICE
  4. The Following User Says Thank You to my third 256 For This Useful Post:
    mudski (30th June 2014)
    177 Post(s)
    Block the EGR.
  6. The Following User Says Thank You to Hodge For This Useful Post:
    Quote Originally Posted by my third 256 View Post
    Exactly. Its a diesel, it will go black regardless. .
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    For diesel oil its normal, to get black much faster than for petrol engines.
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
    Maroochydore, SunShine Coast.
    Quote Originally Posted by ptcb View Post
    You are not the one with problems, it's the guys with clean oil that have the problems, I have worked on diesel motors with centrifugal spinner filters and there oil is still black,
    and we scraped the carbon or soot out of the spinners.
    Drive is 04 DX wagon, 165Ks, Dual Batts, 12000kg Warn in steel bar, Snorkel, Xray 220 Hid Spots, Cruise, digital EGT, Draws in back with power box, 40Ltr Waeco for the essentuals
  10. The Following 2 Users Say Thank You to choppie For This Useful Post:
    macca (1st July 2014), threedogs (4th July 2014)
  11. #8
    Perth W.A
    mate you don't have a problem. Oil in an diesel engine will go black. It's perfectly normal. It means oil it's doing its job.
  12. The Following 2 Users Say Thank You to familyrig For This Useful Post:
    macca (4th July 2014), threedogs (4th July 2014)
  13. #9
    Mar 2013
    Thanks guys for your help. My only concern was if it was going black so quickly. All seems fairly normal then. Cheers!
  14. #10
    Jul 2014
    what grade and manufacture of oil are you using?
