Results 1 to 10 of 15
Thread: LPG with Snorkel
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    LPG with Snorkel
    Hi all, was thinking of putting on a snorkel to my 4.5L petrol with LPG. but the more I look into this the more I think snorkels and LPG don't mix. Has anyone out there had a snorkel fitted with LPG and what was the results? Opposite Lock couldn't sell me one fast enough but ARB said they were reluctant to sell me one with the LPG but would do so if I insisted, after talking to my mechanic he said it would be fine after a tune up but the local gas specialist advised against it because of all the trouble they have seen with them.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    Thomastown, Melbourne
    6 Post(s)
    Why wouldnt you...........................???????????????????//////
    I have a GQ efi that was on gas with a snorkel and when do river crossings the petrol would play up so I would switch to gas and would run like a dream.
    I've never had lpg so can't speak from experience but there are thousands of posts on the net about the ram air effect on a forward facing snorkel can have on lpg but everyone I have spoken to has had no issue so...
  4. The Following User Says Thank You to AB For This Useful Post:
    Chubba (19th June 2014)
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    I have a 4.5 and it on gas. And i have a snorkel. If you have injected gas, youll be fine straight up. A little tune will always help.
    If you have a vapor gas system, youll also still be fine, but you need to put in a cross over pipe, or something to release the pressure (ram air) when you lift off (thats what causes the issues).
    Even tho i have injected gas i still put in a cross over pipe, small pipe going from the bend just after the airfilter, connecting to the intake pipe just after the MAF.
    Another way i have seen is, cutting a hole near the throttle body and covering it with a stubbie cooler, or the likes. Idea being, the air can get out of the intake pipe but cannot get in.
    Talk to your mechanic, hopefully he should know best.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  6. The Following 4 Users Say Thank You to lhurley For This Useful Post:
    AB (19th June 2014), Chubba (20th June 2014), NP99 (19th June 2014), PMC (20th June 2014)
    Patrol Guru Irish's Avatar
    No problem at all running a snorkel with lpg, you just need to run a balance pipe from the "dry" side of the converter to either the dirty side of the airbox or straight out the front of the grill.
  8. The Following 2 Users Say Thank You to Irish For This Useful Post:
  9. #6
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Let me know what you end up doing as I'm interested in putting one on my 4.5 also
    Lucus30's 1999 GU ST TB45E
  10. #7
    Oct 2013
    Adelaide
    5 Post(s)
    will do but still undecided
    "GO YOU CROWS"
  11. #8
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Mine is still in the shed. When we put it on ill do a write up....
    1999 GU 4500 dual fuel
    Il dado è tratto
  12. The Following User Says Thank You to NP99 For This Useful Post:
  13. #9
    Hardcore
    Coffs Harbour
    Quote Originally Posted by NP99 View Post
    Oh, you are such a beast. lol
    PS, its the farken meds mate. lol
    Regards,
    Paul
    The halls been rented the bands been paid, time to see you dance!
  14. The Following User Says Thank You to PMC For This Useful Post:
    NP99 (20th June 2014)
  15. #10
    Feb 2013
    Broadford VIC
    Meds my arse
    Il dado è tratto
