Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: Lightbar security
  1. #31
    177 Post(s)
    The side me and BA live on, is really nice though.
    Sent from my SM-G900I using Forum Runner
    Even though Johnny gets a jerry can full of fuel stolen from his place every few weeks?
  3. The Following User Says Thank You to Winnie For This Useful Post:
    taslucas (17th June 2014)
  4. #33
    177 Post(s)
    It's hard to show digital sarcasm mate. lol
    Patrol Guru Irish's Avatar
    Instead of spending all your spondoolies on flash bolts and stuff, how about just putting a dab of weld on the thread? Sure it won't stop a motivated individual with an angle grinder, but it should deter your average scumbag or force em to make enough noise that you hear and give em a wee attitude adjustment.
  6. The Following User Says Thank You to Irish For This Useful Post:
    rusty_nail (17th June 2014)
  7. #35
    Apr 2013
    I bought a set of lock nuts ...the same as for driving lights...I drilled out and used 8mm bolts with hex heads...still have to get stainless bolts yet because the black ones rust as you can see....you can also use nyloc nuts...just run them on a bolt first then put them on upside down and they wont come all the way off the bolt ...they just keep spinning
    the one thing wrong with middle age ...is knowing you will grow out of it !
  8. The Following 2 Users Say Thank You to menace 2 For This Useful Post:
    clawrence (18th June 2014), Ian2011 (17th June 2014)
  9. #36
    Quote Originally Posted by Irish View Post
    Electronics used in things like led light bars sometimes don't agree with welding. All good for the brackets and bolting them to wherever on your vehicle but not so good for the ones threaded into the housing of the bar itself.
  10. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Irish (19th June 2014), threedogs (2nd July 2014)
  11. #37
    think like a thief what would you be carry around, A six inch shifter a Phillips and flat screw driver and a pkt of tork tools.
    I brought all new stainless bolts[hardware] drilled a hole through the nut and bolt then used a split pin
    but the time they figure it out my dogs would have alerted me.
  12. #38
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Unfortunately my dogs are a little small to be utilised as guard dogs unlike your profile picture Threedogs
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  13. #39
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Lucus30's 1999 GU ST TB45E
  14. #40
    Quote Originally Posted by Ian2011 View Post
    All dogs will bark if something strange is happening. Are they dogs? lol
    Avatar is Billy he's new to the family, Jack was the best man stopper on the planet
    and a big sook as well
    Not a fan of those special nuts all you need is a pair of multigrips.
    Mate just had his light bar stolen and that was recessed into his bulbar.
    If its out of sight silicon would be a good deterrent.
    But for a bit of effort grinding a flat on the bolt then drilling a hole for a split pin
    suits me
