Results 11 to 20 of 33
Thread: Hardyards Ute
    Expert Hardyards's Avatar
    Townsville
    In the tunnel have made it so we can mount bikes or outboard or the dog (wire cage)
  2. #12
    Townsville
    Now the back...Pantry, spice rack (no excuse to not eat well, even out bush) and cellar (36 cans or mix of wine, sprits, beer)
  3. The Following User Says Thank You to Hardyards For This Useful Post:
    Clunk (17th June 2014)
  4. #13
    Townsville
    Slide out fridge, 35 litre Waco, have a 35litre Engle in CT (No favourites here!)
  5. The Following User Says Thank You to Hardyards For This Useful Post:
  6. #14
    Townsville
    Heat exchanger fitted to engine and pipes routed to side for shower. Butterfly valve fitted so cold water can by-pass heater, allowing temp adjustment at shower (not via the heater controls in the Cab)
  7. The Following User Says Thank You to Hardyards For This Useful Post:
  8. #15
    Townsville
    Rear cupboard draws for coffee percolator, saucepans, plates, dream pot and other cooking stuff
    Right hand side contains 2nd battery and isolator, generator, oz pig, tool box, chain saw and assorted storage items (Sorry, no pictures?)
  9. The Following User Says Thank You to Hardyards For This Useful Post:
  10. #16
    Townsville
    Rear sliding draw contains all the recovery equipment, 30lts emergency water bladder, compressor, rake, shovel, axe ect
  11. The Following User Says Thank You to Hardyards For This Useful Post:
  12. #17
    Townsville
    Now the Cabin. Removed instrument panel and fitted blue LED’s. Fitted Boost, EGT, oil pressure and Temp gauges to monitor engine
  13. The Following User Says Thank You to Hardyards For This Useful Post:
  14. #18
    Townsville
    After success with making the rear sliding drawers, I decided to make my own over- head console to house the UHF and some storage. Incorporated volt gauges, circuit breakers, map lights, speaker , extra 12V outlets and a compass from an Aircraft my wife and I both flew. (Finally thought to take some photos during construction)
  15. The Following 2 Users Say Thank You to Hardyards For This Useful Post:
    Clunk (17th June 2014), opinion (21st June 2014)
  16. #19
    Townsville
    Fitted. The volt gauges (start and house battery) can be turned off to save battery when no in use by the little toggle switch on the drivers side. The circuit breakers allow me to isolate any 12v system in the cabin (Shorts, fire ect)
    Attachment 45895 Attachment 45896
  17. The Following User Says Thank You to Hardyards For This Useful Post:
  18. #20
    Townsville
    Went the E-locker option as I don’t have to rely on a compressor, no oil blow back, air lines getting snagged ect (broken wires easily fixed out bush) Love diff locker.. Light switches for roof spotties and rear work light
  19. The Following User Says Thank You to Hardyards For This Useful Post:
