Results 11 to 20 of 49
Thread: Lightbar security
    Yeah torx is not so anti vandal these days but it would hopefully stop an unplanned walk by thief who may only have a standard tool set "maybe".
    There is an anti tamper torx style which requires a slightly different tool. The difference being the tool has a hole drilled in the centre of the torx and the bolt head has a pin so standard torx cannot be used but this stile torx can be bought at most tool shops.
  2. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    AB (16th June 2014), Ian2011 (16th June 2014)
  3. #12
    Quote Originally Posted by lhurley View Post
    If you don't plan on moving it, just use some permenant lock tight. It does come undone if need be, but it's not easy. Hopefully enough to stop a quick opertune attempt at your goodies.
    Yes this could work if you use the high strength retaining compound it would make disassembly quite difficult.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
  5. #13
    Like these ones?
    This is what I have used all over my car. We use them in the playground industry.
  6. The Following User Says Thank You to AB For This Useful Post:
  7. #14
    Legendary happygu's Avatar
    They are the ones I use, and my Baja Designs bar has been on there for three years....
  8. #15
    176 Post(s)
    That Torx style AB listed, is the type used for the MAF sensor on the CRD GU, I think.
    Ohhhh so you mean my fuel tank might get stolen????
  10. #17
    If the bolts are big enough I'd drill and roll pin..
    Could also drill a hole in one of the fins and use steel fishing trace and a solid crimp and tie it onto the bar..
  11. The Following User Says Thank You to BigRAWesty For This Useful Post:
  12. #18
    Like these ones?
    Yes they are the ones.
    Quote Originally Posted by happygu View Post
    Yeah they are still a good thing and tooling would be outside most of the simple minded fools that steel our gear. I'm sure you could hook a very high voltage jolt to it and these clowns would prob get multiple shocks trying to take your gear lol.
  13. #19
    If mine leaks up at the Simpson there is a high probability of yours going missing...lol
    Yeah mate, no ones stealing our aux tanks...lol
  14. #20
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Guess its Loctite and bolt shopping for me this weekend, thanks all for the good ideas. Might even do that steel trace just for extra insurance.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
