Definitely no relay under the cover of my GU 7.
Looking at the wiring diagram there is a set of switch contacts for each headlight, fed by a separate 15A fuse, so 5A through each set of contacts at 12v when on high beam. It shouldn't be an issue for the switch. Anyone heard of switch failures because of this???
