Page 26 of 57 FirstFirst ... 2425262728 ... LastLast
Results 251 to 260 of 565
Thread: Parksy's gq
  1. #251
    Legendary Alitis007's Avatar
    15 Post(s)
    You can check the angle where it fits into the stub axle and i think the length is deferent between gq and gu not sure on the thread tho.
    Talking bout Dynamat, when its packed to be used in cars the price skyrockets but the stuff at bunnings is advertised as a water proofing agent but it does the same job and at roughly $35 per square meter you can go wrong
  2. The Following User Says Thank You to Alitis007 For This Useful Post:
    Parksy (6th June 2014)
  3. #252
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Thanks alitis.
    Wire brushed the bracket and steering box, degreased them, treated them with metal ready then coated them with some seriously glossy paint called Rust Not Epoxy Paint.
    Will fit them in the next few days hopefully.
    IMO and should be taken with a grain of salt.
  4. #253
    Jan 2013
    Nowra NSW
    5 Post(s)
    Old steering box vs new.
    New drag link
    Front main seal has made a bit of a mess of the front end. Corrosion proofing.
  5. The Following 2 Users Say Thank You to Parksy For This Useful Post:
    Bloodyaussie (9th June 2014), Clunk (9th June 2014)
  6. #254
    Don't be fooled George, that bunnings stuff is the bitumen based stuff, and melts at a much lower temp than the butyle stuff..
    Have a browse for our sound deadening thread for more details
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Parksy (9th June 2014)
  8. #255
    Gold Coast
    Very nice truck mate, some well spent time on it.
  9. The Following User Says Thank You to Petrolling For This Useful Post:
    Parksy (12th June 2014)
  10. #256
    Jun 2014
    Eltham
    OH MY GOD parksy this build is absolutely ridiculous! iv been glued to my PC from the beginning. well done mate its amazing! if you ever sell it here's my number... PS how does you wife/family put up with this hobby. hahaha! Can't wait to see more!
  11. The Following User Says Thank You to Timmers For This Useful Post:
    Parksy (13th June 2014)
  12. #257
    Jun 2014
    Eltham
    Quote Originally Posted by Parksy View Post
    Hey drew. It's a 2.5" exhaust, extractors, high flow cat with 2 mufflers. Was a seller off eBay, an exhaust mob in Ringwood Victoria. Can't seem to find them now, then again I haven't exactly been trying to find exhausts lately... But has done a lot in terms of power gains, sounds tough, all the good things. Just need to trim the exhaust tip as I think it's huge!
    Im more then positive the exhaust came from ringwood performance exhaust, which were amazing! but have now moved to vermont. There still amazing though!
  13. The Following User Says Thank You to Timmers For This Useful Post:
  14. #258
    Jan 2013
    Nowra NSW
    5 Post(s)
    Thanks guys. Wife isn't the biggest fan but she knows I enjoy it. Ps you don't happen to work for performance exhaust?
  15. #259
    Jan 2013
    Nowra NSW
    5 Post(s)
    So I had dramas fitting the panhard mount brace. I believe it only fits on patrols with the old style mount which is thinner (I'm guessing). But a quick measure of the mount and I was able to easily adjust the brace to suit...
    Fitted
    I also adjusted the steering box, adjusted the drag link so the steering wheel is centered and made sure the damper is centered properly. Steering is nice and tight and very direct.
    Also removed the covers that sit on the front spring hats and removed about 2 cups worth of sand and mud. I highly recommend that everything check these as you can't see what's going on inside and they could be corroding to the sh1t house.
    Cleaned them out and made sure they were dry. Then got some heavy diff oil and coated the insides and put the cover back on.
  16. The Following 2 Users Say Thank You to Parksy For This Useful Post:
    Bloodyaussie (13th June 2014), NissanGQ4.2 (26th June 2014)
  17. #260
    Thomastown, Melbourne
    6 Post(s)
    Cheer Andy good work as always.... those spring hats love to keep a good half tonne of mud in em thats for sure !!!!
  18. The Following User Says Thank You to Bloodyaussie For This Useful Post:
