Page 382 of 1057 FirstFirst ... 380381382383384 ... LastLast
Results 3,811 to 3,820 of 10566
  1. #3811
    .......... TPC's Avatar
    63 Post(s)
    Finally blocked the EGR, only took me 1 1/2 years.
  2. The Following 2 Users Say Thank You to TPC For This Useful Post:
    Family4x4 (9th June 2014), Hodge (9th June 2014)
  3. #3812
    Jan 2014
    Ipswich,QLD
    Today was power steering belt, new coax and aerial for the two way and wiring up the interior lights to work as one. Now I've just got to figure out how and where I'm going to put my led strip to add to the interior lighting and I'll be set.
    1989 GQ LWB Dual fuel (hopefully not for long) TB42S, 3in efi springs with 5in terrain tamer shocks, roo systems roof cage, custom front tube bar, 32in LED light bar, 285/75/16 federal m/t's, 16x8.5 Dynamic d-hole steel rims
  4. #3813
    Unafordable
    4 Post(s)
    Removed dead aux battery, another one gone! WTF is going on less than 18 months old. past 4 years went through 3x aux batteries 2x isolators, rewired entire dual batteries installation and still can get more than 18 months out of the aux battery.
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    looks like the rubber that goes on top of the springs?????
    Sorry, crappy pic, it was only about a 50mm diameter.
    Hello from Under Down Under!
  6. The Following User Says Thank You to taslucas For This Useful Post:
    Stropp (9th June 2014)
  7. #3815
    Thomastown, Melbourne
    6 Post(s)
    Lucas it looks like the rubber that goes into the chassis mate... look at the end of your radius arms and see if the rubbers are still there? ?
  8. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    taslucas (9th June 2014)
  9. #3816
    How thick is it? To me it looks like a body mount rubber. Radius arm rubbers are mushroom shaped, shocker rubbers, hmm maybe, but body mounts can get really squashed like that looks like. Can't think of anything in the rear of your car that would use a mount like that. Thats a hard one mate.
  11. #3817
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    My guess is body mount related. Maybe once upon a time it was used to fix a clunking body mount?
    IMO and should be taken with a grain of salt.
  12. #3818
    Patrol Guru Family4x4's Avatar
    Jan 2014
    Victoria
    Quote Originally Posted by Rumcajs View Post
    Heat.....?
    In any moment of decision, the best thing you can do is the right thing, the next best thing is the wrong thing, and the worst thing you can do is nothing.
    Theodore Roosevelt
  13. #3819
    Aug 2011
    North West Tas
    56 Post(s)
    It looks like there's rotation marks on it. It's dried out and squashed. Originally red. I had a quick look at the front radius arm mounts but it was dark and covered in mud lol. But could it be the rear radius arm mount to the chassis? That would have to make a bit of a clunk with the rubber gone?
  14. #3820
    Do it look like this lucas? Plus the rear radius rubbers don't rotate. Unless the marks are from a washer that was behind it.
  15. The Following User Says Thank You to mudski For This Useful Post:
    taslucas (10th June 2014)
