Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Blown head gasket
    Sunbury,Melbourne
    If you need to flush oil from the radiator and cooling system,use handy andy dish washing liquid,works well,we use it on the trucks at work,good luck.
  2. The Following User Says Thank You to Roscoe For This Useful Post:
    clivelm (10th June 2014)
  3. #12
    Advanced clivelm's Avatar
    Raby, NSW
    oil light.pngHi Guys,
    Please help. Head just replaced.
    I have run the car for 300kms.
    The oil was white with some water left over from the change. The oil is now as good as gold. Perfectly clean.
    The light came on this morning showing low oil pressure. Please help. Could it be a dirty oil filter after the change?
  4. #13
    Apr 2014
    Perth hills
    That's a bit odd mate, the filter should bypass if blocked, how much crap went into the sump? IE old gasket etc. before you go to far is the wiring to the oil pressure sender unit ok? After a job like you have done its possible to have disturbed it, and is the sender unit working, they can shit em selves and throw the light on. Very cheap to replace too. Get somebody to put an oil pressure gauge on it to confirm.
  5. The Following User Says Thank You to Bushy674 For This Useful Post:
  6. #14
    Raby, NSW
    I will update shortly. Everything is good. Love the World.
  7. #15
    Raby, NSW
    Changed oil filter, oil etc.
    The car is running well after the head gasket change.
    All is running well since.
    Thankyou all for your help.
  8. The Following User Says Thank You to clivelm For This Useful Post:
    snicko (2nd August 2014)
