Results 11 to 20 of 21
Thread: 2 3/4 or 3" exhaust
    Quote Originally Posted by Oldmate1 View Post
    hi guys
    thinking of the beaudesert exhaust but do i go the 409 ss or the 304 ss i go up the beach 3 or 4 times a year but don't know if it worth the extra $665
    to go stainless steel. do most just get the 409
    thanks
    I wouldn't for that extra cost. Just make sure you hose out the underside of your car after a beach run.
  2. #12
    Patrol Freak gaddy's Avatar
    redlands
    hi guys
    thanks
    I got ten years out of a steel exhaust on my last car and I'm on the beach a lot more the 4 times a year ,
  3. #13
    Patrol Guru Rocket55's Avatar
    Sydney
    Stainless doesn't deal with vibrations anywhere near as good as good old mild steel. SS has a habit of work hardening and cracking at the mounting points.
    Cheers Rod
    My Build 2005 TD42TI
  4. #14
    Expert Oldmate1's Avatar
    Mar 2013
    Brisbane. Wynnum West
    Thanks heaps I'll order the 409 from beaudesert yomortow
  5. #15
    Western suburbs of Melbourne
    12 Post(s)
    Give us an update and thoughts when it's done.
  6. #16
    Yep same here, 2.75. I've got the beaudesert system and couldn't be happier
    From all I've read here it appears the Beaudesert 2.75" is a perfect size for the CRD.
    I have a 3" but mine is a Di and I'm happy with it
  7. #17
    Hardcore
    Coffs Harbour
    Hi guys
    Looking at getting a new exhaust but don't
    Know which one is best for the crd.
    Thanks heaps
    Ron
    G'day Ron,
    I assume that you have the 3lt patrol? If that is the case go with a 2.75 or 2 and three quarter inch system. I have used both the 3inch and 2.75mm systems on my old 3lt Navaras and the 2.75mm system performed the best. The 3inch does work on the 3lt motors, however, there is know advantage in performance wise over the 2.75mm system on a stock 3lt motor set-up.
    However, what I did find is that the 2.75mm system performed far better with the stock engine set-up, less back pressure and allowed the turbo to spool-up better. The EGT's were still the same. Also the 2.75mm system is a lot quiet than the 3inch.
    That said; if you are looking for a lot more power and you have don all the relevant pollution blocks, running a larger air intake system and have fitted a chip to your motor, then I would fit a 3inch system to help the thing breath a lot better and help reduce EGT's.
    When I had both systems on the dyno 3 years ago the 2.75mm system had a 2% better result than the 3inch system with a stock 3lt fitted with a snorkel.
    I would give several renowned exhaust system brands a call for there feed-back and also give Reinhard from Berrima Diesel a call he is one of the best Nissan mechanics in the country. He will be the one on which system is the best for the Patrol. He advised me 3 years ago to fit the 2.75mm system to my Navara and he was right.
    Berrima Diesel contact details are;
    Address: 3483 Old Hume Hwy, Berrima NSW 2577, NSW Australia Phone: (02) 4877 1256
    PS, I hope the above info can help you choose the correct system for you!
    Regards,
    PMC
    The halls been rented the bands been paid, time to see you dance!
  8. The Following 2 Users Say Thank You to PMC For This Useful Post:
    Hodge (6th June 2014), Oldmate1 (6th June 2014)
  9. #18
    Mar 2013
    Quote Originally Posted by PMC View Post
    G'day Ron,
    Regards,
    PMC
    Thanks PCM
    I'm think I'm going to put the beausesert 2.75 exhaust on .
    I'll be down your way in October staying at moonie
  10. The Following User Says Thank You to Oldmate1 For This Useful Post:
    PMC (6th June 2014)
  11. #19
    Hardcore
    Coffs Harbour
    Thanks PCM
    G'day mate,
    Let us know when your are down this way, Moonie beach is only 10ks away.
    Regards,
    Paul
  12. #20
    Mar 2013
    Hey Paul
    I'll let you know when I'm down
    Where do you live mate
    Ron
  13. The Following User Says Thank You to Oldmate1 For This Useful Post:
    PMC (7th June 2014)
