Page 378 of 1057 FirstFirst ... 376377378379380 ... LastLast
Results 3,771 to 3,780 of 10561
  1. #3771
    Patrol God Stropp's Avatar
    36 Post(s)
    and now the swivel hubs as well and broken bolts on the gearbox crossmember, i think someone is trying to make it hard for me to go on this trip to the simpson
  2. #3772
    475 Post(s)
    What's wrong with the swivel hub? The cross member bolts are a pain, I have one that's stripped the captive nut in the chassis rail.
  3. #3773
    36 Post(s)
    swivel hubs are like a boghole is how he described them, brown goo
  4. #3774
    82 Post(s)
    Got the radiator back, and was told the minor leak was not the cause of the coolant loss. I followed my mate's advice and took off the fan belt and ran the motor to check for bubbles at the head ( attached a half plastic bottle to one of the sensor holes). When I revved the engine water blurted out so I have taken the head off. Found two of the stainless steel rings on the gasket have split. My mate has taken the head to pressure test and machine. He had a quick check of the known spots that the heads crack and found nothing. Also found that the exhaust manifold was warped, explains why I get fumes under heavy acceleration, so he is gunna machine that too.
  5. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Bloodyaussie (29th May 2014), threedogs (30th May 2014)
  6. #3775
    Beginner aarron's Avatar
    Gday fellas, need some help. My front tyres on my 06 GU Ute were wearing oddly so I got her up on the stands and gave the wheel a wobble, I have movement up and down but NOT side to side, the hub and brake rotor move with the wheel, is it safe to say the bearings are gone? Both outer shoulders (fronts) were more worn than the others but unevenly between the two, is this just a camber issue? Any help would be awesome.
  7. #3776
    82 Post(s)
    G,day, aarron, and welcome to the forum. Do the bearings make a rumbling sound when you spin the wheels. If not, the bearings may just need a re-grease and to be adjusted properly. Try the search function as I am sure there are threads on how to to bearings.
  8. #3777
    Any ideas on the un even shoulder wear?
    Thanks in advance.
  9. #3778
    82 Post(s)
    Check all of the bushes on the front axle and suspension. Also check the swivel hub bearings (king pins). Do the wheel bearings and get a wheel alignment.
  10. The Following User Says Thank You to mudnut For This Useful Post:
    aarron (30th May 2014)
  11. #3779
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Quote Originally Posted by aarron View Post
    Thanks in advance.
    Jack the car up and check for bearing play, if no bearing play check your tyre pressure! Tyre pressure on road is so important just ask a truck driver!. Wheel alignment wont have much to do with shoulders wearing on tyres as there is no camber adjustment on diff. Hubs are secured by the king bing bearings top and bottom.
    If you have movement up and down your king bearings are worn,
    Everyone that owns a patrol should strip one side of a front diff, once you do you'll understand so much more.
  12. The Following 2 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
    aarron (30th May 2014), mudnut (30th May 2014)
  13. #3780
    Adelaide
    9" Ironman Supernova HID lights!
