Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Oil Leak from above oil filter , any idea's
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    It looks like its leaking from that oil cooler that the oil filter bolts onto. My 45 is starting to sweat from around there so i haven't taken it off to see exactly where its leaking from. But be aware there are 2 x heater hoses that attach to it coz the coolant is what cools the oil.
    Hi 007, are they coolant or are they oil pipes that go to a radiator in front of main radiator regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  2. #12
    if you cant get your head in there use a mirror.
  3. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Alitis007 (23rd May 2014), altech (23rd May 2014)
  4. #13
    Legendary Alitis007's Avatar
    15 Post(s)
    Quote Originally Posted by altech View Post
    Those 2 hoses are water hoses mate, the oil comes from the block.
    You might be able to have a better look if you took off the rubber splash guards from the wheel well. That should give a direct look at that cooler/ oil filter housing but you might need to remove the wheel to get your head in closer.
  5. The Following User Says Thank You to Alitis007 For This Useful Post:
  6. #14
    Nov 2011
    Rupanyup, 3388, VIC
    thanks for that info , I thinking leaking oil hose , trick that of list
  7. #15
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys ,I think I have on top of the oil filter unit there the water cooler unit on top , in the middle of pipes there a 16mm bolt which I could tighten up a mm which it slowed it down abit , but if there a seal they I think whole thing has to come out . Guys you think im on the right track or not regards Alex
  8. #16
    Nov 2011
    Rupanyup, 3388, VIC
    Hmmmm should check the Manual next time lol cheers Guys for help
  9. #17
    15 Post(s)
    Your better off changing that "o" ring coz if its gone hard it will still leak even if you tighten the retaining bolt further
  10. The Following User Says Thank You to Alitis007 For This Useful Post:
  11. #18
    Nov 2011
    Rupanyup, 3388, VIC
    All clean and sealed . I wait 24 hours to dry and it was a good thing anyway one of the water hoses cracked up as I was taken it off , So I replaced both regards Alex
  12. #19
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys , oil cooler/filter unit back on block and No leaks . thanks for input over the days Cheers Alex
  13. The Following User Says Thank You to altech For This Useful Post:
    Alitis007 (25th May 2014)
  14. #20
    15 Post(s)
    Great outcome mate!! And thanks for letting us know you rectified the problem. Cheers!
  15. The Following User Says Thank You to Alitis007 For This Useful Post:
    altech (25th May 2014)
