My latest mission is to completely remove the lpg system from the GU,everything under the bonnet is out, the control module under the dash is removed and wiring is all put back to normal next is to remove the tank.
has any one done this before and did you have any problems. I do not have the parts at the moment to install the rear tank and will be running on sub tank only for now.![]()
