Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: K&N air filters
    Apr 2014
    K&N air filters
    Do K&N filters increase power? There expensive! They use oil to trap dust apparently? That sounds like a nightmare to upkeep..
    Western suburbs of Melbourne
    12 Post(s)
    well they increase air flow, in turn giving a little more power.
    very easy to clean from the inside out, let air dry, then re-oil.
    i have two filters that i can just swap and clean and re oil when ever i feel like it.
    they are a little pricey but you only buy once and just keep reusing it.
    i just replace after any dusty trip and at service intervals.
    I have a K&N filter. They work well and any increase in air volume is welcome.
    Although our last Dargo trip was so dusty and when I got home and looked at my filter I couldn't believe it, I won't run a K&N filter on a trip like that again, I will buy a paper filter and throw it out after the trip.
    Those trips is when you need a snorkel sock..
    Thomastown, Melbourne
    6 Post(s)
    I use both... for trips away I use a paper filter and keep a spare but for around town or highway trips keep the K&N in.... found the K&N gets so clogged up on real dusty trips.
  6. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Dave_H (5th September 2014)
    I should have taken a photo of my filter... it was disgusting!
  8. The Following User Says Thank You to Winnie For This Useful Post:
    Bloodyaussie (19th May 2014)
    Your thinking is wrong. K&N filter better at all stages of life than a paper filter. If anything run a paper filter on the road and k&n in dusty conditions.
    Honestly mate k&n all the way. They filter better at higher air speeds than a paper element ever will and will filter better longer in dusty conditions. Obviously as the filter clogs the restriction increases so air speeds increase so this is where the k&n comes into its own.
  10. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Bloodyaussie (19th May 2014), Winnie (19th May 2014)
  11. #8
    I agree with nissannewby on this.
    I don't quite see the logic you blokes are using in taking out a filter that is proven to be filtering the dust out and putting in one that is letting the shit in when you go into dusty conditions?
    Yes, you can throw the paper one away but, Jeez Louise, think of all the poo your engine has swallowed. Logically you should be doing it the other way around
  12. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    NoRush (24th September 2014), Winnie (19th May 2014)
  13. #9
    6 Post(s)
    Hmmmmm.......... !!!!!!!!!!!!!!
  14. #10
    Interesting... thanks for that Matt.
