Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: "CRATE" the GQ
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    "CRATE" the GQ
    Ok guys, I have had this for a while but have only just joined here so will post up a bit of a catch up!
    This is the little beast that got me started on four wheel driving (and patrols)
    Now for my current toy, partly because I wanted the extra space to do longer trips and partly because some flex would be nice once in a while..
    The specs..
    5L Injected V8
    3 link + panhard Front
    4 link + Panhard Rear
    6 Point Cage
    SAAS Racing Seats and 4 Point Harness's
    35's (The Claws from the MQ)
    Front and Rear Airlockers
    Warn High Mount, Radio's (AM and UHF), CD Player
    and all fully engineered for everything
    Also came with dirt, dents, rust, stuffed bushes and really stuffed shocks
    Some more Pics..
    Why it needs drop out cones..
    And for some reason steering stoppers too, (dw the gouge is no where near as deep as it looks)
    And my really squashed/rusted roof gutter
    So then the revamp started
    All new bushes underneath
    All new shocks
    Dropping down from 5" to 3"
    Steering Stoppers
    Rear Drop out cones
    New front bump stops
    New pads and rotors in the front
    Steering knuckle rebuild
    New front doors
    New sound deadener and vinyl throughout
    New flares
    The 35" MT Claws off the MQ (MTZ's on it are really only good for spares)
    Knocking out dents cutting, out rust and a general touch up
    The 1.75" Chromo hex bar links.. every link is made out of this stuff
    New Bump stops (Pedders 80 Series Landcruiser Rear's $100 for the pair)
    Diff out work in progress
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
  2. The Following 4 Users Say Thank You to Crate For This Useful Post:
    AB (19th May 2014), Family4x4 (19th May 2014), growler2058 (19th May 2014), jack (19th May 2014)
    Apr 2014
    Bonbeach
    Did some rust repairs..
    Cutting out the rust..
    Fitting the new section in..
    Welded in..
    Some more.. yeah welding isn't so good.. but im happy with it for my first crack at sheetmetal!
    Then I used some rust converted and painted it all with acrylic cold gal..
    Can see in this one where i patched up ALL the stupid holes in the floor.. now the water can only get in the doors
    [/img]
    Also started on the crushed and rusted roof gutters.. straightened and cleaned up here..
  4. The Following User Says Thank You to Crate For This Useful Post:
    Avo (19th May 2014)
    Apr 2014
    Bonbeach
    All new bushes in and linkages back in.
    New shocks and steering dampener are here, rears installed.
    Got some secondhand swivel hubs, and new stubs, nuts and cone washers for the high steer.. you can see why in the pics below..
    Sound deadening all done inside.
    Fixed up the chop and made some 100mm flares for the right hand rear.. only 3 to go :roll:
    Ok so pictures of progress..
    The links are all in now.. this is just after painting
    The floor after some cold gal and chassis black..
    The silver on the left is resomat.. and the right is waterproof underlay foam..
    The welded on high steer arm.. covering up the sloppy king pin bearings..
    You can see where the weld breaking took a big chunk out of the side.. so to be safe got new swivel hubs..
    Guard chop all neat.. have 60mm to the nearest part of the guard on the front.. where my shocks bottom out with 35" MTZ's.. Should be able to fit 37's.. if ever necessary
    8)
    Apr 2014
    Bonbeach
    OK pics of links all in.. and shiny new bits.. including drop out cones
    Guard chop is almost finished (3.5/4)
    New grille parkers and tail lights on order should arrive this week
    some random bits painted more to go..
    Testing..
    Apr 2014
    Bonbeach
    Progress..
    Flares that cover the bit between the outer and inner guard too..
    Stone guard to replace that shitty bit of plastic in front of the rear wheel, and also on the bottom of the doors..
    Oh and seats back in..
    Apr 2014
    Bonbeach
    So then it was finished (or so I thought)
    and bogged for the first time..
    Here is a little vid of me saving some guys in a jeep Rolling Eyes (its better with the sound on)
    http://youtu.be/Qrf3csKWcOI
    Few things on the list to fix up as there always is.. including my first dint in the new paintwork! And perhaps an exhaust that isn't stupidly loud.. but mostly working on building my new carport shed to keep it in!
  9. The Following User Says Thank You to Crate For This Useful Post:
    Avo (19th May 2014)
  10. #7
    Apr 2014
    Bonbeach
    So after all that work getting it up to scratch suspension and body wise I got it out for a run twice and the engine rings decided to disappear and let oil be burnt! So after a 2 week engine rebuild it was ready for a Walhalla run:
  11. #8
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Sweet mate good build thread
    Lucus30's 1999 GU ST TB45E
  12. The Following User Says Thank You to lucus30 For This Useful Post:
    Crate (19th May 2014)
  13. #9
    Nice build mate. Looking very good. Can I see some pics of the cage and the side rails please. Did you buy it with the cage and Engineers? Is it CCDA approved? Looking to maybe do a non approved cage in mine as I will never race.
    Looking to do the side bars front and back in the coming months.
  14. #10
    22 Post(s)
    Hey mate.
    Did you design the 3 link yourself?
    Can you throw up some pics up of the way the links mount to the chassis please?
    96 GQ coil/Cab
    08 G6eT
