Page 64 of 88 FirstFirst ... 6263646566 ... LastLast
Results 631 to 640 of 875
Thread: Bloodyaussie's GQ
  1. #631
    Heres some ratios i found a little while back while i was doing some research
    <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=44513"/>
    So it seem the only difference is between is auto and manual..
    Thomastown, Melbourne
    6 Post(s)
    I have a fuel issue it seems but am putting out 80kw...
  3. #633
    177 Post(s)
    I actually have to go back and see Mark as he thinks my Turbo is cactus and wants to dyno it properly. Thanks for the reminds BA!
    Patrol Guru Irish's Avatar
    Question, the stock figures for the tb42 are for around 129kw, but is that measured at the crank or wheels?
    I'm assuming thatit's at the crank, else your rig is waaaay down on power.
  5. #635
    6 Post(s)
    Well Mark pretty much works mostly on 4wd's and has built many of the engines in the racing scene and says they are good kw figures and I would be hard stretched to get better results??
  6. #636
    Guessing the 129 is crank tested then, does he have any solid thoughts on whats throwing your fuelling out of whack?
  7. #637
    Quote Originally Posted by Irish View Post
    129kW would be measured at the flywheel, and probably exaggerated a bit too.
    80kW is great for a TB42E. Jonathan remember that before I did anything to my car it had 80kW. More torque but still.
  8. The Following User Says Thank You to Winnie For This Useful Post:
    Bloodyaussie (14th May 2014)
  9. #638
    6 Post(s)
    He said my pump is stuffed as he tested the flow and pressure... George wants me to check that the pump is getting 12v and to borrow a Fuel reg before spending on another pump.
    I dont have a spare reg here I dont think? and to test the pump is getting 12v I have to drop the tank which means removing the tow bar....blah!!!!
  10. #639
    Do I have a regulator on any of the sh*t at mine?
    If I do you can grab it.
    The regulator!!!!!
  11. #640
    6 Post(s)
    I dont know... I just went outside to see if I had an injector rail but I dont seem to??
