Page 63 of 88 FirstFirst ... 6162636465 ... LastLast
Results 621 to 630 of 875
Thread: Bloodyaussie's GQ
  1. #621
    Patrol Guru Irish's Avatar
    Far out, gearbox too?!!! Gimme a shout if you need an extra set of hands.
  2. The Following User Says Thank You to Irish For This Useful Post:
    Bloodyaussie (13th May 2014)
  3. #622
    Feb 2011
    Shed
    45 Post(s)
    Chuck in MAtts box.....................
    Oh yeah, Shoulda got a LoKKa
  4. The Following User Says Thank You to growler2058 For This Useful Post:
  5. #623
    Patrol Guru matfew's Avatar
    Nov 2012
    GU shifter is in a different spot from what i am told.
  6. #624
    Quote Originally Posted by matfew View Post
    Yes it is too.
    Bummer, could'a had a good gearbox for ya...
  7. #625
    It is but this part all bolts on to the same box pretty much so it could be possible to swap the tops over. The ratios are different in the 1st 3 gears though in the gu.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
    Bloodyaussie (14th May 2014)
  9. #626
    Thomastown, Melbourne
    6 Post(s)
    Now am I right in that the TD42 also has different ratios???
    Taken the day off and have to repair exhaust and am waiting for a call bacl from 360 gearbox and at a quick mention they said $2950 ...... FARKK !!!!!!!!!
  10. #627
    I am not 100% on that one mate but I thought they were the same box as both the petrol and diesel operate in near the same rpm range the petrol just goes to 6 where our diesel doesn't. It will be in the manual if you have time to look.
  11. #628
    Legendary Alitis007's Avatar
    15 Post(s)
    Heres some ratios i found a little while back while i was doing some research
  12. #629
    6 Post(s)
    Well I have finished with the exhaust... there were leaks everywhere.. had to pull off the tail pipe as it was leaking heaps from there.
    The welding went well and never knew you could get welding rods as low as 2mm... great for these little jobs where thin metal is to be welded.
    Will go for a drive after lunch and see if there is any difference with the smell in the car??
  13. #630
    6 Post(s)
    Well a strange thing happened.... I went up to JPC to speak to Mark about my car and ended up leaving it there and walking home.
    It is getting a dyno run so all the guessing ends now hopefully.... a bit nervous actually.
  14. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Maxhead (14th May 2014)
