Page 362 of 1057 FirstFirst ... 360361362363364 ... LastLast
Results 3,611 to 3,620 of 10566
  1. #3611
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Put my front diff back in, bolted the hubs back in. Crawled under to zip tie the air locker line up, realized I needed another. I slide myself out from under the car and whack! I'm seeing stars. I then remeber that I do have blood that runs through me, and now outside of me too...LOL
    Turns out that a tie rod end is tougher than my scone.
    Attachment 44271Attachment 44272
    Ohh fark!!! that is ahhmm , ahhm, ahhh , hilarious ..bwahahha...hope all is good mate
    ________________________
    ______ 2017 D-Max _______
  2. The Following User Says Thank You to Maxhead For This Useful Post:
    Alitis007 (8th May 2014)
  3. #3612
    Western suburbs of Melbourne
    12 Post(s)
    I'm not sure what's funnier , you bang'n ya head, or everybody laughing at it. PML
  4. #3613
    .......... TPC's Avatar
    63 Post(s)
    Those guys are inconsiderate bastards but I care, here you go.
  5. #3614
    Just larf at both...... I did and feel so much better for it
  6. #3615
    84 Post(s)
    Yeowww! That looks terrible, Mudski.
    I undid the Old Trol's front few body mounts and slid in a few rubber washers, which I had cut out of old inner tube. Used a bit of super glue and then tightened the mounts up. The noises when braking and turning have stopped. It will do until I can afford some new mounts.
    Unfortunately, the radiator has been flexing with the movement of the old mounts. Last week I saw that the solder had broken between the top strut and tank, so the core is weeping, the same place as it had done two years ago.
    Today, I made a large soldering iron out of a bit of copper pipe, a thin metal rod and a bit of pine for a handle, (no one sells the soldering irons down this way). I used my gas weed burner to heat it. It took a few goes, but the tank is secure, but the core is still slightly weeping. I will put a little bit of chemiweld in to stop it. (I know, I know. It is not great for the engine, but it has worked for over 2 years) It will have to do, until I can afford a new radiator.
  7. #3616
    63 Post(s)
    Will have to start calling you MacGyver. lol
  8. The Following User Says Thank You to TPC For This Useful Post:
    mudnut (7th May 2014)
  9. #3617
    I'm not one to laugh at others pain but... Oh who am I kidding that's farkin hilarious!
    I wasn't larfin' when I did it though. I have never cut my head before and didn't realise how much a head can bleed. Whats even funnier that I whacked my head on the way under too.
  10. #3618
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    what size lift kit you have?
    Not a 4 inch then,
  11. #3619
    Quote Originally Posted by sil3nt_dr3ams View Post
    Not a 4 inch then,
    2inch now, but was on stands too...Next week it will be 4inch with any luck...
  12. #3620
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    Got me a water bag. Look like I'm from yobbo-ville now hahahahahaha. I have soaked the bag for like 6 days and dried it out 3 times and still leaks. Not much but is that normal or will it eventually stop leaking all together?
