Hey, hoping some bright sparky can identify this wire and attached thing which has come loose near the alternator.
I want to know what it is, what it does and does it look broken? If not I'll zip tie it somewhere safe...
Cheers, Lachie
Cheers, Lachie
GQ Safari 2.8TD. BFG AT's / Safari Snorkel / Straight thru exhaust / Lots of electrical mods
Not sure what it is for mate, but from that second shot, it looks like it has borken off a mount. I'd be tieing it up in the interim just to be safe.
Thanks mate, yeah it's definitely snapped off. Can't find where it was mounted and no idea how it broke - protected position and weighs about 10 grams!
Looks like a Radio Interference suppressor. It looks like a piece of the mounting bracket has broken off (probably due to vibration). You will most likely find the rest of it under a screw somewhere within the radius of the length of the wire. Get another one from Repco / Supernotsocheap / Autowhatsit or any auto elec.
lachiek (11th March 2011)
Qualified Auto-Electrician
Apprentice Sparky
Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
You guys are legends thanks! Turns out I've been looking to replace my aerial cause the reception is so bad...
Shouldn't it still work even though the mount broke off?
Nope - it wont work unless one end is earthed (the case) and the other end is connected to the power rail (+12 volt). With it not connected you may get alternator whine - a noise in the radio (and even in the CD player in some cases) which gets worse as you rev the engine.
Thanks mate. I think you just saved me buying a new aerial!
Dont mean to flog at dead horse but yeah
it' s a noise supressor
Someone's Gotta Break 'Em... So It Might As Well Be Me!!.
