It sounds as if yours might be one of the vehicles in which a 50mm lift can put castor out enough to be annoying. I'll be interested to hear the response as I'm considering some sort of castor correction and none of the three options are particularly great.
1. Castor bushes, generally flog out pretty quickly 2. Correction plates......???
3. Drop boxes, probably a bit extreme for 50mm but also reduce clearance.....less if an issue if your lift is 100mm
4. Drop arms etc. Ideal but expensive.
Sent from my iPhone using Forum Runner
