Results 1 to 10 of 17
Thread: Unidentified loose wire from alternator
    Expert lachiek's Avatar
    Sydney CBD (for my sins)
    Hey, hoping some bright sparky can identify this wire and attached thing which has come loose near the alternator.
    I want to know what it is, what it does and does it look broken? If not I'll zip tie it somewhere safe...
    Cheers, Lachie
    GQ Safari 2.8TD. BFG AT's / Safari Snorkel / Straight thru exhaust / Lots of electrical mods
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Not sure what it is for mate, but from that second shot, it looks like it has borken off a mount. I'd be tieing it up in the interim just to be safe.
    Thanks mate, yeah it's definitely snapped off. Can't find where it was mounted and no idea how it broke - protected position and weighs about 10 grams!
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Looks like a Radio Interference suppressor. It looks like a piece of the mounting bracket has broken off (probably due to vibration). You will most likely find the rest of it under a screw somewhere within the radius of the length of the wire. Get another one from Repco / Supernotsocheap / Autowhatsit or any auto elec.
  5. The Following User Says Thank You to BillsGU For This Useful Post:
    lachiek (11th March 2011)
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    My thoughts exactly
  7. The Following User Says Thank You to Dhuck For This Useful Post:
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    That's exactly what it is.. It's a noise suppressor.. the wire will run to the main battery bolt on the back of the alt and the unit just bolts to earth.. they are used to cancel out small voltage spikes ect that might cause interference (like static in radio)..
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  9. The Following User Says Thank You to big_fletch For This Useful Post:
  10. #7
    You guys are legends thanks! Turns out I've been looking to replace my aerial cause the reception is so bad...
    Shouldn't it still work even though the mount broke off?
  11. #8
    Jul 2010
    Thurgoona
    7 Post(s)
    Nope - it wont work unless one end is earthed (the case) and the other end is connected to the power rail (+12 volt). With it not connected you may get alternator whine - a noise in the radio (and even in the CD player in some cases) which gets worse as you rev the engine.
  12. The Following User Says Thank You to BillsGU For This Useful Post:
  13. #9
    Thanks mate. I think you just saved me buying a new aerial!
  14. #10
    Expert MS29431's Avatar
    Nov 2010
    NTH EAST SUBURBS MELBOURNE
    Dont mean to flog at dead horse but yeah
    it' s a noise supressor
    Someone's Gotta Break 'Em... So It Might As Well Be Me!!.
