Page 360 of 1057 FirstFirst ... 358359360361362 ... LastLast
Results 3,591 to 3,600 of 10566
  1. #3591
    Advanced pickers's Avatar
    melbourne
    Added some LEDs to my rear door table
  2. #3592
    Beginner Dave_GU_ACT's Avatar
    Jan 2014
    Quote Originally Posted by Patrol-Guy View Post
    How hard is it to convert tail lights to LEDs?
    I got a loom from the rear of a falcon sedan and put led globes in them. Used a hole saw to make the hole then used a semi round file to just make it fit.. Was pretty easy then wired it in from the lights in the bar..
  3. The Following User Says Thank You to Dave_GU_ACT For This Useful Post:
    Patrol-Guy (5th May 2014)
  4. #3593
    Jan 2014
    68 led T20 will fit in the front parkers make for very bright DRL to.
    Yep on order from brightlight auto. I only use them. Even though they are a little on the dear side, their lights are very good as the Chinese ones aren't very bright.. When it's dark I'll take a few snap shots.
  5. #3594
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    Quote Originally Posted by chrisc2306 View Post
    You can buy bayonet led bulbs that just fit in place of the standard ones
    Thanks, is there a need for resistors?
  6. #3595
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Hit limp mode for the first time ever! 19psi in third gear..
  7. #3596
    Expert chrisc2306's Avatar
    Feb 2014
    Wanaka, New Zealand
    Nope no need for resistors just replace the standard ones with led style ones and away you go. This is the ones I got obviously they are 24v because I have a safari but you can get 12v ones too
    http://www.ebay.com.au/itm/221423169...84.m1423.l2649
  8. The Following User Says Thank You to chrisc2306 For This Useful Post:
  9. #3597
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Refitted the BMS head unit
    While I had the ceiling down I decided to relocate the Redarc BMS head unit to the overhead console. Routed the head unit cable up the B Pillar and across the roof.
  10. #3598
    Tracing the feared 24v to 12v converter wires! :O they are all cut....
  11. #3599
    Adelaide
    Replaced the front 31-10.5x15 tyres
  12. #3600
    Quote Originally Posted by BenK View Post
    How did you go removing the roof lining from the front window rubber??
