Page 19 of 57 FirstFirst ... 1718192021 ... LastLast
Results 181 to 190 of 565
Thread: Parksy's gq
  1. #181
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Quote Originally Posted by Parksy View Post
    Thanks all. I plan on putting the lower door trim what ever the hell they're called things back on. Just need some uber strong double sided tape. Anyone recommend a good product? Will also be putting the roof rack on once i find some suitable rubber to use under all the mounting points so there's no metal contact.
    Find the supplier panel beaters buy from and get some of the 3m tape they use for body kits.
  2. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    Parksy (4th May 2014)
  3. #182
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    x 2. 3M double sided rubberised tape. You can get it on eBay as well.
  4. The Following User Says Thank You to FNQGU For This Useful Post:
  5. #183
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Cheers guys. Went to autobarn yesterday to find the 3m stuff at $25 for 5m!! I had a heart attack. Never thought to look on eBay...
    IMO and should be taken with a grain of salt.
  6. #184
    Jan 2013
    Nowra NSW
    5 Post(s)
    Got excited when I found this, but on closer inspection...
    http://www.ebay.com.au/itm/3M-Auto-A...f95a47f&_uhb=1
    This one is an aus seller. Notice the 3m logo on the tape
    http://www.ebay.com.au/itm/3M-Double...09cdb07&_uhb=1
  7. #185
    I just brought some 3M x 25mm double sided last week, great for sticking my mike bracket to the dash.
    It is very strong if its the red stuff.
    Do you really want to put them back on ,just seems it a place for crud to collect.
    Patrol looks awesome as is
    Black chrome wheel nuts ?????????
  8. #186
    Jan 2013
    Nowra NSW
    5 Post(s)
  9. #187
    Yeah same shop the lot, No sure if its pressure sensitive or not, have plenty of that from mates at Qmart.
    I only got it as changing mike position from driver side to passenger side, to give c0-pilot some imput on trips
  11. #188
    Mar 2013
    If you want to make sure its lined up pro pertly before you press tape up against panel then have rip it off. Instead leave the back film attached to tape then just lift a corner poke it out so you can grab it press panel in the pull the film out from behind it. haha hope that made some kind of sense. Haven't got thru my first cup of coffee e yet.
  12. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
  13. #189
    Jan 2013
    Nowra NSW
    5 Post(s)
    Thanks silent dreams. Made perfect sense. Great idea!
  14. #190
    Leave em off. Much cleaner without them.
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
