Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: nissan patrol y61 4" lift kit
    Feb 2014
    brunei darussalam
    hello all patrol expert..need some advise on 4" lift..im currently installed adjustable pandhard rod,shock and spring 100mm,extended swaybar link,
    the question is..is drop box needed for better comfortable ride?and how bout the 5deg castor plate?is it necessary ? or ill just install the dropbox..ive been doing some reading,that the 5deg caster plate is only for 5" above..thanks for any advise
    Feb 2014
    brunei darussalam
    and by the way..my patrol seems unbalance..its like more heavier on the right side..i dont know how to explain it..lol..im not very good on english..when i check the height..left side is off about 1inch and right side is less 1inch..that aint normal is it?or my coil spring must switch viseversa to fix this..
    Western suburbs of Melbourne
    12 Post(s)
    1" difference is little off, perhaps driver side springs were fitted to passenger side.
    I believe driver side are slightly taller.
  4. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    seekers282 (26th April 2014)
    Feb 2014
    brunei darussalam
    okay..that might be the solution..im gonna check my oem standard spring..which one is taller..thanks mate
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Quote Originally Posted by seekers282 View Post
    Hi,
    If you have left hand drive vehicles over there then I would expect the drivers side to be a little higher than the passenger side when empty. This is done to accommodate extra weight of the driver.
    Jack
    2024 Isuzu MUX
    12 Post(s)
    Quote Originally Posted by Apollofish View Post
    Hi, If you have left hand drive vehicles over there then I would expect the drivers side to be a little higher than the passenger side when empty. This is done to accommodate extra weight of the driver.
    And sub tank.
    Feb 2014
    brunei darussalam
    and about my 1st question..anyone can answer it? about the drop box issue..if i install the drop box..do i still need to install the 2-3 deg caster correction bush?or just use the standard bush?1
    Legendary happygu's Avatar
    No need to use both together....
    Use Drop Boxes over Caster Correction Bushes, as you can then keep the Standard Nissan rubber Bushes - much better
    Mic
  10. The Following 2 Users Say Thank You to happygu For This Useful Post:
    Rickie3 (27th April 2014), seekers282 (26th April 2014)
  11. #9
    Feb 2014
    brunei darussalam
    Hi,
    well mine is right hand driver vehicle..
  12. #10
    Feb 2014
    brunei darussalam
    Quote Originally Posted by happygu View Post
    Mic
    ok thanks happygu ..im gonna have to swap the 2deg bush thats currently installed back to standard bush..
