Results 1 to 10 of 14
Thread: Auto shifting into 4x4 tips
    Mar 2014
    Perth
    So might be a stupid question but I have a 2013 st plus. what it's the trick to shifting into 4x4 smoothly with an anto gear box up until now I've had manual
    so I was out doing a bit and got the good old grinding every now and then when shifting low to high and other way.?and I'm aware you can change on the fly under 40 kph but (grind) oops !!! In a whole it's my first time 4x4ing with an auto so any tips would go down like. A Cold beer on a warm day
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    From 2 high to 4 high just back off the throttle a bit and slid it in.
    From 4 high to 4 low you really should be stopped.
    If I have to go from 4 high to 4 low if stopped on a bit of a hill or at times when the box is loaded up etc, I put the auto into neutral to relieve any pressure on the box then slide into 4 low.
    Hello from Under Down Under!
  3. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    Alitis007 (20th April 2014), growler2058 (20th April 2014)
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Hi mate,
    There should be a placard on the drivers sun visor, it says when changing between 4H to 4L or 4L to 4H to ALWAYS STOP your vehicle.
    Let me know if it's missing and I'll take a picture and post it up tomorrow.
    Enjoy the auto.
    (Tried to take the pic but the flash is to strong)
    Jack
    2024 Isuzu MUX
  5. The Following User Says Thank You to jack For This Useful Post:
    Battleready76 (20th April 2014)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by Apollofish View Post
    Hi mate,
    Enjoy the auto.
    Correct, plus Transmission must be placed into "neutral" when selecting between H & L
  7. The Following User Says Thank You to 04OFF For This Useful Post:
  8. #5
    Mar 2014
    Perth
    Thanks guys yea I've always stopped for every change but my old bus was 24 years old and well old but the new is a bit different ,I think the problem I had was that I was pushing lever down to much as in saying that I push it down to select low or high but no sure switching between the low and high do you still need to push it down or just shift like normal .i only had to change 4l to 4h a couple of times but as I said I'm new to the auto .so I dare say its best just to stop select neutral and change as needed I get it next time I'm sure just hate to grind especially when the wife is next to ya saying nice one nob nuts
  9. #6
    Feb 2011
    Shed
    45 Post(s)
    Yup low to hi or himto low neutral and slooooooooow or stopped same with my 90 GQ manual
  10. #7
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by Battleready76 View Post
    The pushing "down" movement is simply a safety lockout feature, designed so you do not move the lever too far into the Low range selection accidentally while the vehicle is in motion.
    Pushing down should not be required between 2H and 4H (just pull back), only push down to bypass the safety lock to get into Low range 4x4, at this time the vehicle needs to be stationary , and transmission in neutral.
  11. The Following User Says Thank You to 04OFF For This Useful Post:
  12. #8
    Apr 2013
    instructions on sun visor
    the one thing wrong with middle age ...is knowing you will grow out of it !
  13. The Following 2 Users Say Thank You to menace 2 For This Useful Post:
    Battleready76 (20th April 2014), taslucas (20th April 2014)
  14. #9
    Apr 2013
    Hmmmmmm...a bit hard to read...anyway , it just says what everyone else says
  15. #10
    Mar 2014
    Perth
    Ahh now it's all so clear I just pushed here and pushed there only need to push for low range ,,,,saftey lockout to 4L that's clinched it for me
    Never met a more helpful bunch of blokes hats off to you all
  16. The Following 2 Users Say Thank You to Battleready76 For This Useful Post:
    04OFF (20th April 2014), jack (20th April 2014)
