Results 1 to 10 of 14
Thread: Help. No dash or tail lights
    Aug 2013
    Hello to all ...
    I am hoping someone can assit with my problem(s) re the dash and tail lights on my 1990 RB30 patrol.
    Basically I have no dash lights or tail lights (including reversing lights)!
    The fuse are ok! all warning/indicator lights (indicators, park brake light, high beam, 4x4 wheel indicator light etc work ok, but there is no illumination in the dash nor do any of the tail lights operate. The brakes lights work when the peddle is depressed.
    So please where do I start?
    Do the front Parker lights work.
    I'd check your fuse again for a start. Even swap it out with another just to confirm (cheap)
    Also put it in reverse with the ignition on ut engine off and check with a multi meter that you have not got 12v at the globe. I believe the reverse light is a separate circuit??? Maybe not though? Everything else is on the same fuse so I'd start there mate.
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Nissan cedric (16th April 2014)
    Do both head lights work?
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Advanced Matty852's Avatar
    Mar 2014
    Darwin, NT
    Have a look at the actual fuse connections as well, I had some dramas with mine, I pulled the fuse and it looked fine and I didn't notice that the connections in the fuse block were all old and corroded
  7. The Following User Says Thank You to Matty852 For This Useful Post:
  8. #5
    Aug 2013
    Yes both work. And so does the high beam. No parking lights though
  9. #6
    Aug 2013
    Ta will try that. The fuse looks good. But did not think to check the connections
  10. #7
    Aug 2013
    Ta will try that
  11. #8
    Aug 2013
    Hi matty852. Tried and still nothing
  12. #9
    Have you got a Multi meter? If so take out the fuse and turn the lights on and see if you have 12v at the fuse holder? If you do then you know which side of the fuse your problem is. Just take an earth off the body and test the cues holder for current both sides. You will have 12v on one side only.
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  14. #10
    If you still have OE globes then the chances are the lead on the connector is worn, sometimes when you hit the lens the globe will light up.
    To remedy the problem fit new globes.
    check all earths as well
