Page 54 of 88 FirstFirst ... 5253545556 ... LastLast
Results 531 to 540 of 875
Thread: Bloodyaussie's GQ
  1. #531
    Quote Originally Posted by happygu View Post
    What is the actual litres per hundred of yours BA, and Drew's. Clunk should be able to chime in with his too, as a comparison.
    Then Bob will can come along and tell you how bad it is, you lead foot! Get a tom tom hahaha
  2. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Drewboyaus (6th April 2014), growler2058 (7th April 2014)
  3. #532
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Maybe your ecu map is a bit out of sorts and it's holding your injectors open too long
  4. #533
    Oct 2011
    Essendon
    I'll top it up tomorrow when I take it down to wash that stinky as sh!t Tallarook mud off it and let you know how much I put in.
    Sent from my iPhone using Forum Runner
  5. The Following User Says Thank You to Drewboyaus For This Useful Post:
    Bloodyaussie (7th April 2014)
  6. #534
    You won't have to pull the fuel system out.
    Just locate your return on the tank, if it goes to the rear tank you'll be able to get it via inspection hatch in the cargo area.
    Add a peice of line to it to clear the cab or drop it in front of the tank into a bucket, start it up. At idle it should be a good flow.
    Thomastown, Melbourne
    6 Post(s)
    I cant get to the inspection hole... I can check it down along the chassis but where it may have run into grief is just before the tank as it was a really tight fit with all the extra fuel lines for the Aux tank after I took all the gas out.
  8. #536
    Does the return line go from solid to rubber at an easy to get to spot?? Can you divert it at that joint?
    Maybe try and blow some air down the rest of it..
    Oct 2011
    Essendon
    41L I got in there and I travelled 162km since I filled up......works out about 24L/100km I think.
    Not too bad for low range driving.
  10. The Following User Says Thank You to Drewboyaus For This Useful Post:
  11. #538
    6 Post(s)
    Quote Originally Posted by Drewboyaus View Post
    Hmm ok I think I need to do some sums... I will fill up tomorrow and drive 100km then top up again and see what numbers I get.
    This will be city driving and later in the week I can do a highway run and do another comparison..... then report back with my results.
    Thanks Drew.
  12. #539
    Oct 2011
    Essendon
    No worries. Was just thinking that you also have a couple of extra inches lift on yours and I'm also running the skinnier tyres that have a reduced rolling resistance.
  13. #540
    6 Post(s)
    Ok I did 50km exactly towing a very heavy gardening trailer with it full for nearly the whole 50km in city driving and put 12 litres in....
    Now to do the other 50km tomorrow on the freeway... going to the RAAF base to take the kids out and we will see what results I get there??
    The smell I get in the cab is more like an oil smell as today (maybe as it is cooler day) there it was really strong.
    I've been told its because I am running petrol and because I have not finished the quarter chop but I ran petrol a lot before I took the gas out and I never got this smell in the cab before... it burns my eyes when it's really bad.
    Hmmm....
