Results 11 to 20 of 21
Thread: 2009 GU Recovery Points
    177 Post(s)
    Soak in CRC and walk away mate if you haven't already. Soaking is important, I see people so many times spray it and instantly try and have a go at the bolt. Let CRC to it's magic for a bit and then let it rip... Mine were tight as well as I done just that spray from above and below and concentrated on something else for 20 minutes, and when I came back they undone right off.
    Feb 2014
    Iceland
    I had a better way - went and saw a mate who has a rattle spanner
    Made easy work of those bolts
  3. The Following User Says Thank You to apalsson For This Useful Post:
    Hodge (7th April 2014)
  4. #13
    177 Post(s)
    Quote Originally Posted by apalsson View Post
    Or that. haha Good stuff.
    Just a suggestion but I recommend getting a 12 Volt Impact Wrench off Ebay.
    They cost about $50 and I have used mine for everything from wheel nuts to rebuilding diffs.
    Only thing is the wheel nut sockets they come with are rubbish but a few extra bucks at a Tool shop or Coventry's for a 21mm Impact Socket and it's game on.
    Link is for illustration only... I don't know this seller so cannot recommend them one way or the other
    http://www.ebay.com.au/itm/NEW-12v-E...item4ad0947d1d
  6. #15
    X2 with Evil I have used the same 12v impact tool ever since they came on the market, I brought mine from Kangaroo Creek imports for $98.
    The best part is they are fully re-buildable if something fails as in the switch in my case, just upgrade sockets as suggested
  7. #16
    X3 Best bit of kit I own! Looks like Junk but is un-matched IMO. when its time to give up is when i pull that sucker out!! makes light work of most things.
  8. #17
    Jul 2015
    Scarborough, WA
    and yes that loop is ok for a light tug but nothing serious thats for sure.
    I'm new so excuse the daft question - are you saying the stock recovery points front and rear are not rated for recovery if I get bogged? I've got a 2012 ST Patrol 3.0Ltr and looking at 'essential' upgrades -is this one? Don't want to spend the $$ if I don't have to as am eyeing other mods.
  9. #18
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    The factory ones arn't very strong mate. I have just fitted Threedogs (outback ideas) rear and another "rated" (sorry TD) brand to the front. Just have a look at the difference and you will see why. TD's rated rear is fully welded and twice as thick as the spot weld thing that comes on the standard patrol. Front also welded plate not just a hook. Spend the $'s and get them upgraded IMHO.
  10. The Following User Says Thank You to 4bye4 For This Useful Post:
    00marshall (12th July 2015)
  11. #19
    Aug 2010
    adelaide
    have to use an extension on mine as the socket isnt long enough for the front mag wheel the locking hub is in the way
    OH LEATHER IS NICE
  12. #20
    Quote Originally Posted by my third 256 View Post
    I used an old 4" extension, works a treat.
    @ MR they are fully rebuildable and not that many ppl know that.
