Use grey rope to tape it to a pole
oncedisturbed (2nd April 2014)
Basic design done....All I need now is a couple of leaf springs...
2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
Nah I'm good to go, I'll make mine from mild steel.
Later I'll do a spring steel copy. Think I've ticked most boxes as well.
All I did was throw a heap of tool in a pile and made one design with all tools in it.
And I might add even a signalling mirror oh yeah baby, Boom baby Boom
Are we showing design now as we will all be different I think, Im done just need some holes
and an edge put on it but shape wont change
Leaf springs.. Geeze were getting thick now..
It's an interesting concept the multi tool.
Any pic of their favourite TD?
I gotta finish the bloody car off then ill make a couple. Still got heaps of L6 steel from the saw blades.
Made 2 and have been informed both are wicked and hold a mighty edge.
threedogs (4th April 2014)
http://www.ebay.com.au/itm/Bracers-A...item23323dfcbb
http://www.ebay.com.au/itm/300-Spart...item232bc66ae1
@ OD thought you might like this
@ Kallen its not going to win any beauty shows but it needs to do heaps of things for "Survival" that's why its more a tool.
The one I'm doing now is a dummy for the real one, pretty chuffed as it ticks most of the boxes, a handy "TOOL"
oncedisturbed (4th April 2014)
What thickness?
My L6 is 4mm.. Probably on the thin side..
Another use to build in, tent peg lifter??
Bottle opener / can opener
I'm thinking a rather wide but stubby dagger..
I went along the lines of a cross between a mattock and a pick,
I'll put up a pic but its way from finished,
The curved under edge is the knife on top will be a saw,
that bung of steel is the hammer the handle will have para cord
to tie a shaft to it as a spear, there will also be a hole in the middle
so you can use as a mattock or pick, Plus I'll polish steel so its reflective as well
but yeah pretty happy so far, the spear part is in the handle.
@ Kallen more survival than camp duties,
edit pic could be better sorry
BigRAWesty (4th April 2014), Gecko17 (4th April 2014)
I have scanned my design but it's in pdf format.... How can I upload that?
way more to do but I'll chop and change this one then translate that onto the leaf spring one,
bummer thought I had some here as I had the fire going
heres my OE drawing
