Page 347 of 1057 FirstFirst ... 345346347348349 ... LastLast
Results 3,461 to 3,470 of 10561
  1. #3461
    Thomastown, Melbourne
    6 Post(s)
    Here you go
  2. #3462
    Expert ripper's Avatar
    Leeton NSW
    Quote Originally Posted by Chimo View Post
    PS can one install 16'' wheels on a GQ and which ones are the way to go and is the range of tyres (more HT that AT type) much better in the 16" wheel size?
    We've currently got a set of steel factory GU wheels with 265/75R16 (31 inch?) tyres on our GQ Chimo.
    I bought them secondhand to reduce the revs a bit when we're towing our van. They bolted straight on and don't scrub anywhere.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  3. #3463
    6 Post(s)
    The size mentioned above are 32's
    As for 16 inch rims no problem.. I run 265's and 285's...
  4. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    ripper (1st April 2014)
  5. #3464
    265s are the OE size on GUs and GQs with STD 16' rims
    265s return great economy which you'll find out after switching to 285s
    Most here would run 285s or 305s
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Chimo (1st April 2014)
  7. #3465
    Nov 2013
    Gold Coast
    I have the standard 15" rims and have 31 10.5 15 AT tyres that result in the speedometer being 5 or 6 kms slow at 100 110kms.
    Given that 16" rims presumably result in a far greater range of HT tyres which I am thinking about as 98% of my running is on road with a bit of 2 tonne plus towing
    1 what are the most reasonable choice in such tyres and
    2 what is the speedo error likely to be?
    Thanks in advance
    Chimo
    and PS 3 Anyone in shouting distance of the Gold Coast got anything I might need for sale? (preferably second hand)
  8. #3466
    10r 15s x 31 are smaller than STD so great acceleration, and high revs at hwy speeds
    A set of 16" x 8 rims with some 265s would be back to STD, slightly less acceleration but lower revs at hwy speeds
    at hwy speeds, 285s are about the same as a 33" but only 11.5 " wide, not sure if they would fit on a GQ with STD suspension.
    With a 2" lift yes, check what off set is required , rim wise
  9. #3467
    Leeton NSW
    I suspect your speedo will be more accurate if you put 32 inch tyres on. Ours was fast by more than 10% with 31 inch tyres, now with 32's it's back to about 5% faster than reality.
  10. #3468
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Got some some new rock sliders. Replacing the rusted and bend ARB ones.
    Also got a clip on rear view mirror that has blue tooth for the phone, Front facing recorder and a rear camera.
  11. The Following User Says Thank You to meh For This Useful Post:
    threedogs (4th April 2014)
  12. #3469
    Advanced Pokey's Avatar
    Mar 2014
    Tassie
    Fitted the new monster intercooler today. Can't wait for the exhuast to arrive !!1396517178744.jpg
    I plan to live forever................going well so far
  13. #3470
    176 Post(s)
    Got an extra button of confidence fitted today.
    Attachment 42846
    Attachment 42850
  14. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Bloodyaussie (4th April 2014), threedogs (4th April 2014)
