Results 1 to 10 of 16
Thread: Post recall issue
    Expert NewDan's Avatar
    Oct 2011
    Post recall issue
    Hey all,
    Mine was one of the Patrols where the accelerator pedal problems were very evident, accelerator going limp then engine cutting out while coasting to a stop.
    I had the recall done around a couple of months ago with no problems at all....... that is until today, same problem, accelerator pedal goes limp then while coasting to stop the engine cuts out. Always restarts though.
    Just wondering if anyone else has had the issue come back after the recall was done.
    #1. 2007 Walkabout, Auto, 2" EFS lift, DP chip, 3" Exhaust, cross country intercooler, front and rear diff locks, manual torque convertor lockup, bulbar, IPF driving light, Dawes valve, Boost, EGT and transmission temp gauge, 80 Channel UHF, Black widow storage system, ARB duel wheel carrier. 215 Litre fuel. #2 GQ 95Ti TB42e.
  2. The Following User Says Thank You to NewDan For This Useful Post:
    Avo (29th March 2014)
    no because I have 2 GQ's.......... but I reckon you should take it right back to Nissan and get them to sort it
  4. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    NewDan (30th March 2014), Rickie3 (30th March 2014)
    Western suburbs of Melbourne
    12 Post(s)
    I've had mine done for a month now but I haven't had that problem yet.
  6. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
  7. #4
    Oct 2011
    Hey Guys thanks for that, I'll call Nissan on Monday but im guessing they will dis-own the problem saying they have already done the recall and its now my problem. Ive heard they can be hard to deal with when it comes to intermittent faults.
    Dan
  8. #5
    their PR skills could do with some polishing
  10. #6
    177 Post(s)
    Take it back mate. Mine played up a week after recall job. Took it back and they fixed it a day later no questions asker. From memory they replaced the unit again. This was... Many months ago and no issue since.
  11. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    NewDan (30th March 2014), threedogs (30th March 2014)
  12. #7
    Oct 2011
    Many thanks guys, I suppose its important to know it can still happen so to keep an eye on it. Ill let you know how I go with Nissan
    Dan
  13. #8
    Yea, Victoria
    Mine was one of the first here (I think) to be done. I reckon that its 80% fixed. I say that because a couple of times now I have noticed a difference in the pedal position. Only short drives each time and the next start all was back to normal. So I reckon that Nissan still has some issues...
  14. The Following User Says Thank You to Coldcomfort For This Useful Post:
    NewDan (1st April 2014)
  15. #9
    Oct 2011
    Local Nissan dealer has booked it in for Next Monday to have another look, funny thing is as part of the conversation service department asked me to describe what was happening, when I got to the part that the engine cuts out she said "It shouldn't do that" I said but that's exactly what is described in the recall. The response was " Oh in that case Ill book it in"
    Dan
  16. #10
    get it all in writing, dates times work done etc ,seen it here too many times
    Hope you get it sorted,
    Mine being a DiD I've just fitted an ECU-talk that monitors TPS voltage etc.
    might pay to purchase the correct consult protocol device to suit the CRD,
    you can then clear any errors instead of going to Nissan all the time
