Results 1 to 10 of 14
Thread: Confusion?? Help appreciated 2" Lift for 2002 GU II
    Expert tikashooter's Avatar
    Dec 2013
    G'day All,
    I have been reading the Suspension & Body Lifts posts / answers in relation to getting a 2" lift and I'm a little confused to what I should be looking for or need to consider and not waste money ie
    1/ castor correction, would this be advisable to get and to negate any potential handling issues?
    2/ radias arm spacers, is this a good option to negate any potential issues?
    3/ steering dampener replacement, it probably is original.
    4/ I want to clarify what bushes that should be checked / replaced?
    5/ any recommendations to which lift kit I should be considering and from where?
    6/ what is the maximum rated payload I can achieve with upgrade or is there no change?
    I have a 2002 GU II 3.0 Litre with an automatic transmission, factory bull bar ( winch to be fitted in future ),
    running Lt 265/75R16 tyres, its done only 115000 klms and it also has a fridge & home made draw system permanently installed at present.
    Looking forward to your thoughts & advice.
    Tikashooter
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Hey mate if your just after a 2 inch lift springs and shocks should be fine there is no need for the other stuff
  3. The Following 2 Users Say Thank You to 93patrol For This Useful Post:
    Family4x4 (8th May 2014), tikashooter (17th March 2014)
    Legendary happygu's Avatar
    Quote Originally Posted by tikashooter View Post
    G'day All,
    Tikashooter
    No requirement for Caster Correction, as most trucks still track fairly well with the 2" lift, but you can choose to do it, to restore the geometry to factory.
    No Spacers required,, especially with the older flares on the 2002 models and small tyres
    Steering Damper is up to you, as it may be fairly worn by now, but is not required usually.
    Check all bushes and bolts - replace as necessary - but not knowing the condition of your truck makes it hard to comment
    Stick with the major kits and you wont have any dramas - plenty of threads and answers about specific kits here too
    Payload wont change, although you may have less sag with heavier duty rated springs
  5. The Following User Says Thank You to happygu For This Useful Post:
    Dec 2013
    Thank you very much,
    Advanced Ironman 4x4's Avatar
    Jun 2013
    You won't need radius arm spacers unless you are looking to run 35s on a 2" lift.
    Other than springs and shocks you don't "need" to replace anything else. Though if you did desire, swapping to an adjustable drag link means you'll keep you steering wheel centered (rather than it sitting permanently on a slight angle) and if you upgrade that you may as well upgrade your steering damper too (though if you are running small tyres and keep them well balanced you really don't need to upgrade).
    I'd suggest just doing springs and shocks first. Enjoy the improvement in ride quality. Once you've had that in for a while you'll get an idea of what you like and what's annoying you and you can make decisions from there!
  8. The Following 2 Users Say Thank You to Ironman 4x4 For This Useful Post:
    Family4x4 (8th May 2014), tikashooter (27th March 2014)
  9. #6
    mine has a 2" efs no other bits and pieces although I would like braided brake lines
  11. #7
    Mar 2014
    Mildura Vic
    When you put in the 2" EFS lift was their specific springs for driver & passenger sides
  12. #8
    Thomastown, Melbourne
    6 Post(s)
    Quote Originally Posted by Mac53 View Post
    There always is!!!!
  13. #9
    Yep. You will notice with any lift the drivers side is slightly longer to off set stock things like driver, battery etc.
    All springs should be marked LF, RF, RL, RR or similar.
    Jul 2011
    yeppoon Qld
    Hi.
    GU111 '02 3 ltr.
    King Springs 2in lift "PROGRESSIVE RATE" springs. with EFS H\D Shockers.
    Great on corrugations dirt. and the Progressive rate makes bitumin comfort soooo much better.
    IE Softer rates at start of spring compressions..
    Another good thing is a Suspension seat. (Mine is Stratos. Truckies)
