Page 19 of 26 FirstFirst ... 1718192021 ... LastLast
Results 181 to 190 of 254
Thread: Nissheads GU8
  1. #181
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by Dave_H View Post
    Nice setup mate. The watchdog you have will that plug into my 08 gu6 3.0crd?
    It sure will mate, any CRD
    ________________________
    ______ 2017 D-Max _______
  2. The Following User Says Thank You to Maxhead For This Useful Post:
    Dave_H (23rd December 2013)
  3. #182
    Expert Warwick89's Avatar
    Oct 2013
    Cairns
    Mate probably a stupid question but how many different sensors does that unit read straight from the car?
  4. #183
    ACT
    Quote Originally Posted by Warwick89 View Post
    It should read any sensor in the vehicle and you can get an optional attachment for EGT temps.. but if I had my time again I would probably go with a Scangauge.
    I explained some issues in this thread ...I'll try and find it for you so I don't have to retype..LOL
    Here:
    I got the watchdog on Amazon for I think $204 but looks like they have gone up a little. http://www.amazon.com/Bully-Dog-4040...ords=watch+dog
    it is a good unit except when you have it set to metric units the boost is displayed in KPA which is a pain but you learn the reading pretty quick so no biggie.
    Also the wiring needs 12v not like the scangauge.
  5. #184
    Oct 2013
    Cairns
    So other then the KPA readings there is no big downside?
    2010 GU7, ZD30 CRD. ARB: bulbar, scrubbars, rock sliders, roofrack, front and rear air lockers, twin compressor. OME 2" lift, mickey T's ATZ P3 33" tyres x 6, opposite lock rear twin spare rear bar, Wurton 46" light bar roof mounted, draw system, clearview mirrors, redarc gauges: boost, EGt, engine pressure and temp, trans temp, battery. Dual battery system, 12,000lb warn winch, DYI sound/heat proofing.
  6. #185
    ACT
    Not all a mate, it actually teaches you to drive to obtain maximum fuel efficiency through throttle control and braking...its pretty good
  7. #186
    Oct 2013
    Cairns
    Sorry for all the questions but if that's the case why would you go a scangauge?
  8. #187
    ACT
    No problems mate but it's because Im lazy and my brain is too slow too convert boost pressures from KPA to PSI and wiring an extra 12v to the unit was a pain...LOL
    BTW the unit will work without ACC 12v, but it will stay on constantly
  9. #188
    Advanced Mitch.mccabe's Avatar
    Aug 2013
    Lightning Ridge, NSW
    hey nisshead, I noticed the 7inch navigator, was this the all in one job from Nissan? I have one of the Nissan jobbies in my 2013'. Trying to find out if I can update for topos like oziexplor, or hema map type setups
    GU Series 07/2013 Y61 Patrol -Bullbar and Spotties, Side Steps, 5 Speed Man, Newly added ARB Alloy Roof Cage, Snorkel
  10. #189
    ACT
    Quote Originally Posted by Mitch.mccabe View Post
    Yey Mitch, no its an aftermarket unit from eonon which is OK but nothing special. I don't think you can get oziexplorer onto the Nissan ones unfortunately. BTW, these things are only $300 and come with navigation and you can run ozi on it..LOL
  11. The Following User Says Thank You to Maxhead For This Useful Post:
    Mitch.mccabe (17th March 2014)
  12. #190
    ACT
    Single flywheel heavy duty clutch is in and feels great!!!
    Feking Nissan wanted $4600 to replace the old one after 30000km...lol
    Conversion and new clutch was 2000 bucks and it feels sooooooooooooooooooo much better...lol
  13. The Following User Says Thank You to Maxhead For This Useful Post:
    growler2058 (17th March 2014)
