Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 87
Thread: National check your nuts day
  1. #51
    OK fellas and Gals time to get out and have a fiddle with your nuts . Big 5 day Easter break coming up
    last thing you want to happen is see your wheel fall off and the damage that goes with it.
    If you're not up to it get a garage or friend to check for you, it could be expensive
  2. The Following User Says Thank You to threedogs For This Useful Post:
    Off Tap (17th July 2014)
  3. #52
    brisbane
    2600$ when it happened to my missus and you can add on 1200 for a alloy gu rim if you want a new one lol
  4. #53
    Yahoooeeeee,I get to check Mrs Possums nuts...might go do it right now,thenks for the thread and the reminders..
  5. #54
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Quote Originally Posted by wa 489 View Post
    You can check mine next time we are down lol
    www.swat4x4.com
  6. #55
    after recent events it would pay all GU owners to check and tighten their nuts to OE specs.
    Always re check after 20ks, might save some tears.
  7. #56
    Patrol Guru TimE's Avatar
    Canberra
    May as well post this Video here as well
  8. The Following 2 Users Say Thank You to TimE For This Useful Post:
    Fry (29th April 2014), threedogs (29th April 2014)
  9. #57
    Jul 2014
    Geez, first I've heard of this problem
  10. #58
    You are despicable lol sooooo wrong I like it
  11. #59
    Quote Originally Posted by Off Tap View Post
    what are you driving???
  12. #60
    Advanced warner01's Avatar
    Jan 2014
    morphett vale
    Why oh why didnt i recheck my nuts.
    Went for an id check for my conversion but had to change from my sunraiser rims to my mags due to tyre size, on my way back the wheel came off my gq. I had to walk 200m to get the dam thing. thankfully a guy stopped in a ute and took the wheel and me back to the car, then began the jacking up and repositioning 5 times before i could get the wheel on. end result. need new rotors, pads and i busted my fiberglass flair. not too bad conidering but money i coulda spent elsewhere.
    lesson now lernt ALWAYS pull over after a short drive and recheck you nuts...
  13. The Following 2 Users Say Thank You to warner01 For This Useful Post:
    snicko (25th July 2014), threedogs (25th July 2014)
