Results 1 to 10 of 14
Thread: Extractor time..
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Extractor time..
    Even tho I am going to turbo, until I get all my research together I would rather wait.
    I broke a few exhaust mounts last week on 4wd trip, so I figured if I'm going to play with the exhaust I might as well put them headers I have hanging on the wall. I'll admit I'm winging this one using what I have on hand and hope I have an exhaust by tonight.
    Its only got to last couple months.
    Mar 2013
    Wont be wining any welding awards lovely gas less mig.
  3. The Following 2 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
    Stropp (9th March 2014), threedogs (10th March 2014)
    Your motor will thank you for allowing it to breathe.
    Don't forget the flexible joint ?
    Mar 2013
    They wont be in there long enough. If you take a look at a lot of kits and on patrols a lot don't use a flexi join. I know its bad but its not a long term solution
  6. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    wonder if your fuel figures will improve, will be interesting to see.
    stock exhaust, headers and turbo with 3" system LOL
    Mar 2013
    haha, i'll bin everything from the head backwards. Its now a full 2.5 inch lucky system with wildcat headers.
  9. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
  10. #7
    Cairns
    Hey Threedogs you helped me before and im turning to you (and the forum) for a little more advice please... I just spied an old set of extractors for my RB30 in the wreckers - they are pulling them off now (paid just $110 - which i dont think is too bad up here in Cairns where such finds are rare) I might also get the whole system if its not been crushed under the body.
    If i do need to get a whole new bottom end (Extractor to tail pipe) Should i assume that a 2 1/2" bottom end is the go? im thinking it would maintain some backpressure rather than 3" on a 3l motor? any thoughts on this??
    also i see mention of a flexible section, again i assume that is advised? (Im not running any lift yet, plan a 2 " susp. lift in future tho) when maybe i can do a few more challenging (read rougher) tracks when shes up and running
    GQ RX3 . The good things: she has doors, windows, and wheels ... !
  11. #8
    2.5 is perfect for a Na car mate..
    As above a 2.5" will give you a extra gear if combined with some headers.
    Might even give you a bit of a note as a plus.
    Any mod that helps a stock motor breathe has to be good.
    IMO this is the only performance mod that might see you better your fuel figures
    once you slow down a bit after the excitement after first fitting it all.
    I did this mod on a 3F petrol Tojo big improvement now I drive a patrol, bigger improvement lol
  13. #10
    Cairns
    Nice thanks. fingers crossed it comes off the doner in 1 piece!
