Results 1 to 3 of 3
Thread: Fuel Tank Pressurising.
    Gday, I have just finished converting my patrol back to straight petrol.
    Now I have a problem with the tanks pressurising, whenever I stop I have to open the fuel cap to let some of the pressure out.
    My question is, 1. what would be the cause? and 2. how do I fix it?
    Beginner aiKzo6's Avatar
    Mar 2011
    Is the charcoal canister connected correctly (ie, hoses going into the right places, check valve pointing in the right direction)? If it is, make sure the vapour/vent (hose from the tank to the cannister) isnt kinked or pinched anywhere. Then make sure that purge valve and hose (cannister to motor) are also connected properly.
    Aiks
  3. The Following User Says Thank You to aiKzo6 For This Useful Post:
    HILLBILLY BOY (8th March 2011)
    I had a look last night after I posted this and found that the check valve that I didn't bother hooking up as the filler neck I got from the wrecker had an extra breather hose on it so I just hooked it from there to the little breather hose on the tank.
    I have since changed this, blocked the filler hose breather and fitted a "T" piece joining the two tanks through the check valve to the motor.
