Results 1 to 4 of 4
Thread: Gu patrol runnig rough on lpg
    Mar 2014
    warwick qld
    Smile Gu patrol runnig rough on lpg
    Hi all. New to this site and have a question for all.
    Have LPG/PETROL and when engine is running on LPG it starts to run rough like it is not get the LPG through, it not running rough all the time just now and then, switch back to PETROL and it runs smooth again. You can smell gas when you stop after it has been running rough.
    Any help would be helpful.... Jim
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Jim, I think the car is tuned for petrol , So try moving the distributer to left or right after you start it on LPG and see if that make a difference, but be4 you move the dizzie Mark a set point with a colour texter regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  3. The Following User Says Thank You to altech For This Useful Post:
    jimsav61 (10th March 2014)
    Gas likes it advanced ,so just before it Pings on petrol would be spot on,
    Most gas problems are electrical so make sure your leads are clean and in good nick.
    Retarded it will sound like a flat battery starting it
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    BP LPG can play havoc on some systems....
    1999 GU 4500 dual fuel
    Il dado è tratto
  7. The Following User Says Thank You to NP99 For This Useful Post:
