Thanks for the help so far.
I have now been toying with the idea if using a temp sensor to monitor cooling temps. I'm kinda thinking that if I'm going to do it once, then I should do it right the first time.
a) Has anybody fitted a surface temperature sender in case of a loss of coolant? Would this setup be more thorough then the radiator hose adaptor setup? If so where would you the sender?
b) has anybody fitted the pyro pre-turbo, straight into the middle if the manifold? Is there a splitter that you need to mount in the middle of?
Thanks,
Cam
