Results 1 to 10 of 52
Thread: Dual Batteries or one single
Threaded View
    brisbane
    Quote Originally Posted by Ronin View Post
    yeah they are not cheap.. just the unit itself is 450 and u have to add a battery to it. But they do have all the connections I could need including a 240v output.
    450$ sounds like a lot but if you were to make it yourself it adds up fast but I bet you would get a better unit at the end of the day. if you were to get a battery monitor also the ark wouldn't be such a bad option though mind you i added a bit on these prices as I'd be using baintech plugs and USB and cheaper parts could be used.
    battery box $74 20 if you get a blank one
    Merit,cig cig plugs 60
    Anderson plug 20$
    Inverter 60$- 300$
    Dual USB plugs 65$
    Ctek 7amp charger 145$ ebay
    Isolator switch 30$
    Around $450
  2. The Following User Says Thank You to megatexture For This Useful Post:
    Ronin (6th March 2014)
